400rwhp NA possible?
Ohio5pt7
Ohio
What does it take to get to 400rwhp na? Stock bore. I'm thinking LT's, vararam, ported TB, tune, full exhaust. Would that get me there 8speed 4x4 CC.
It'll take a cam and ported heads/intake to pull 400NA rwhp from a Hemi.Your combo listed will get you to maybe 360 at the tire. My 8 speed with 3.21's and 29" tires dyno'd 355hp and 375 lb-ft with your same basic mods.With a 75 shot it went to 435hp and 455 lb-ft.
Ohio5pt7
Ohio5pt7
Ohio
Have you tracked it? What's it run?
Sent from my SAMSUNG-SM-G891A using Tapatalk
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Just need the cam with bolt-ons to get 400whp. Eagle heads flow enough for almost 500hp
Runs 12.21's at 3500ft DA.The 8 speeds are usually 320/330 hp at the tires.Bolt-ons and a tune won't give you a 80+ rwhp gain,it'll take a cam and head work to get to 400 at the tires NA.
Pull Ya
Cedar Creek, Tx
^^^ Rick(Wild one) knows what he is talking about from everyday experience. I think he has the fastest 4th Gen in Canada.
Jay
Ohio5pt7
Ohio5pt7
Ohio
Is your truck a CC or 4x4? That is a great 1/4 time. Maybe I should have named this what does it take to hit 12s full weight lol. That is kind of the goal I just figured it would take 400rwhp
Pull Ya
Cedar Creek, Tx
You might also talk to Matt at Moe's Performance for suggestions and recommendations. I think every truck he has raced has been in the 11-12 second range. Although I think they are all RCSB trucks I think his experience will help you in your goal. His current truck is the first 4th Gen. to run in the 10's.
Jay
McBroom
Denison Tx
Hemi 6.4L
^^^ That right there^^^
Matt @moesperformance
That man knows how to make horsepower.
He’s a great guy too
I love my truck!
Blue Mule 18 Ram 2500 4x4 C/C Off Road.
WilliamS
Tampa FL
NA your gonna need Cam at the minimum and likely valves and springs and spin that bad boy way up!
Tach_tech
5.7L HEMI
Wildone, what’s your uncorrected time for curiosity sake?
12.21 @ 109 is uncorrected Dan.It still holds the fastest time slip for a 4th Gen in Canada "yet",but there should be some quicker trucks coming on board this year,lol.If Kurtis/Charonblks new build works out,he should be the one to beat.Young Josh out of your town with his Eddy blown 4X4 has gone high 12.5's over at the Hat.On paper you should be one of the quicker trucks if not the quickest around,if we ever get you drug out a track,hint/hint,lol.Couple of the Saskatoon guys are upping their nitrous shots to 150+ in the hopes of taking my truck out,lol.Mines pretty conservative as far as builds go,a bolt-on truck with one of Jay's 1.5HL cams and a small 75 shot,but it seems to work good for what it is.
Rick
It's a 4X4 regular cab shortbox Sport Ohio
Tach_tech
5.7L HEMI
Rick
Ah, I thought I saw you say before that was a corrected time. Good stuff.
I don’t know if my truck would beat a 12.2 though. Not sure if the extra 70whp would make up the weight difference of a crew cab to reg cab.
Dobaramguy84
Tonwanda, n.y
how about a 6spd rc? ive been tooling around the idea of putting shorty's on the truck (since apparently new York sucks) and doing a 90mm tb with spacer and cold intake and tune as well.
Depending on who's DA correction factor I use,it corrects into either the high 11.70's or low 11.80's. My buddy Lawrence has had his bolt-on Scatpack 6.4 Bee on the same dyno as your truck,and he's dyno'd 505 hp and 500lb-ft,and my truck usually has his Bee covered by almost 2/10ths,which ****** him off to no end,my dyno numbers are a lot less then his,and the truck out weighes his Bee by over 600lbs.The best one was when we got a speed on green ticket leaving the lights in Edmonton,the first photo shows the truck with a fender on his Bee,the second one shows the truck leading by almost a full length,and they sent him the ticket,lol.Being as it was a good friend,i split him on the ticket.I tried to get the ticket out of him,but the bugger won't give it up,lol.There's a couple guys that call my truck a Unicorn,as it shouldn't run like it does,lol.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Driver Mod :D:D
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Post the pics with the plates blurred! That's awesome. :cheers:
