.50 cal stubby
vpalace
Havertown, PA
Looks cool, where did you pick it up from and how is your am/fm reception now?
Kicksncaps
Kicksncaps
New Orleans
Got it from Cravenspeed. I'll have to see about reception once I pick up my truck today... did this right before dropping it off to get painted. I only really use my ipod in the truck or the xm on occasion.
sent from my big ass Note 3
vpalace
Havertown, PA
I'll check it out. Easy to replace? I tried to remove my antenna before I went into the car wash a few weeks ago and could not get that sucker off!
Kicksncaps
Kicksncaps
New Orleans
It's a bit of a ***** if you think you can just unscrew it... the chrome circle that has like 3 flat indentations is the part you need to unscrew first. After that's off you can lift it and unscrew the actual antenna
vpalace
Havertown, PA
Oh, didn't know it screwed in twice. I couldn't get the indented cap off even with a pair of vise grips.
Kicksncaps
Kicksncaps
New Orleans
I used a flat head screwdriver to tap it loose then did it with the pliers
2711
HEMI 5.7
Keep us posted about the reception
Kicksncaps
Kicksncaps
New Orleans
Just as what seems to be consistent with the reviews of other stubby antennas I noticed a slight drop in reception today as I tested it out on the weaker stations but still seems fine. Easy enough to swap out if I go on a roadtrip.
Lemniscate_Mike
