Burla
- Apr 28, 2012
- 27,545
- 57,766
- 2010 Hemi Reg Cab 4x4
- Hemi
5w-30 doesn't affect MDS very often if at all, however it does affect the VVT on my 16 on the first cold start.
So, I can't run even a partial crankcase of 5w-30. 5w-20 seems a bit thin when towing @ 70 mph to Florida in heat of July and August. 0w-30 mixed with 5w-20 works perfect for my uses
Side note, dealers just in the past couple of years started using 5w-20 BLEND on their oil changes, prior to that it was conventional 5w-20.
However, I wouldn't go 10k miles on conventional if you plan on keeping the truck for the long haul.
I'm using 5W20 full synthetic. Love the synthetic oil!
Oil threads never dieWell for me I run 100% synthetic and what the manufacture specs call for ! I live up in Maine a couple hrs over the border from Canada so sometimes gets real cold :O , I made my switch from conventional oil to full synthetic in the 90's in mt F150 w/a 302! On super cold mornings it would turn over slowly because of the thicker oil from the cold ! :O When I switched to 100 synthetic it turned over like it was summer, so I was hooked lol What one is better ??? BUT what matters most IMO in just change the oil when called for ! For me I think full synthetic is better in the long run from all I have read ! but who knows :O
I've found it to be true in motorcycles that the synthetic doesn't form carbon deposits around the piston rings like conventional will not sure it would be the same for the Hemi.
Kurek, my POV, your question is fair. The assumption or suggestion that the manufacture has the best interest of the vehicle and the customer in mind is flawed. The manufactures often make a recommendation or set specs that have nothing to do with what is best for the vehicle. Today they are driven by political decisions and socialist rules. CAFE standards, warranty rules, lemon laws etc. The days of the engineers know best and they design and spec the vehicle to last longer, are behind us. They spec the thinnest oil they can get by with. Reduce drag on rotating parts. They spec 80lbs air pressure in the rear tires of 2500 trucks. Less tread resistance. Horrible ride. They let, out of spec parts get into assembly. It is a economic gamble for them. The dealer will fix those that complain. Most will make it to trade in before they fail. MDS gets them CAFE standards as 4 cylinders drag the other 4 cylinders through the firing sequence. Ford's engineering is even better. Engine shuts off at stop light. High speed starter starts it back up when you depress the gas. How does that effect a 5.0 truck engine when it is 115* outside running on low temp thin oil. Got their CAFE rating. Fitz
I also ran Synthetic in my bikes as well. Mobile 1 MX4T because of the wet clutch ! Added it to my lawn mower and will use it in the generator when I use up the regular oil.. My buddy;s HD he went full synthetic for everything and ran better and drive train quieter !FULL Synthetic always. FULL in my Motorcycle also. Now lawn mower, riding mower, just straight HD 30, LOL.... 5W20 winter, now U can either stay with it in summer or if real hot/hard working in summer U could go to 5W30. Since mine does lil hard work, tho stupid hot here, 5W20 works for me. ALL IMHO.....
ADDED: Oil change intervals regardless critical. ALSO, in winter, try to always get to OP temps for a while, not halfway, too much condensation than...Just IMHO..... But man my harley was bad for that, my Honda, not so much...
DO NOT use 5w-30. Bearing clearances are way too tight on that motor. Let the other guy destroy their engines because they “know” better. Use a quality 5w-20 synthetic and you will have no issues at all.....
As a matter of fact many domestic cars use oils other than 5w20 overseas and the manufacturers are okay with it because 5w20 is not avail. in many places.I smell an agenda...Understand that viscosity is just a measurement related to temperature. So if what you say is true, when 5w20 is cold it can be 100 times thicker than 5w30 at operating temp, not hyperbole but actually 100 times thicker. 5w30 operates at 12 viscosity, but oil is always moving, so when 5w20 is cold it can easily be viscosity 1200 or higher, much higher. So how can 5w20 move through bearings if it is that thick? The answer is those bearing tolerances aren't as tight as you believe. Fca doesn't even say that, they say 20 weight is needed for mds, which has been proven to be a lie as well.
But one fact is, there has been widespread issues with hemi's and lubrication, and most of those trucks were using 5w20. Could those failures been prevented with heavier oil? Dunno, but maybe. I bet every single person that shelled out money on a failed Cam wished they at least tried some of the oils this forum has experimented with. Then, you at least know you tried, and then if the truck died, oh well you did all you could. 5w20 is government agenda oil, that's it that's all. When FCA got to choose an oil because HD's are out of governmental control, they choose a 40 weight oil full of additives.
Nothing to do with bearing clearances..........running 5w-30 here turning 6500rpm @ WOT with 77k on the clock.DO NOT use 5w-30. Bearing clearances are way too tight on that motor. Let the other guy destroy their engines because they “know” better. Use a quality 5w-20 synthetic and you will have no issues at all.....
