BlownGP
- Joined
- Feb 10, 2013
- Posts
- 6,082
- Reaction score
- 1,573
- Location
- Houston/Baton Rouge
- Ram Year
- 2018 RAM Harvest New Holland Blue
- Engine
- 5.7
After I finally installed Jessie's part I thought about getting rid of that 3 way hoses. I thought something looked weird when I changed the T-state. lolIf you only remove the heater lines and leave the tstat then it’ll just take longer but it’ll still get over 180° as that’s the Tstat temp. Without removing the tstat and blocking secondary passage to limit flow only to the cooler then temps will eventually reach normal temps. By blocking the actual heater passage as the rev max kit does to limit oil flow only to the cooler you will have lower temps because 100% of the oil gets cooled.
I didn't know there was a line to warm up the oil too. Wild one told me that.
Was thinking it might run a little cooler but there's really no point with Jessie's part. Warming the truck up faster really is not a big deal to me especially in the winter time as long as it runs cool when it gets up to temp I'm good.
