9.25" upgrades
ramchrisfla
5.9 Magnum
So I now realize that I have a 9.25 and definitely happy about that. Not only did I save myself the headache of swapping another 9.25 with Anti-slip...now I have the opportunity to upgrade something truly gnarly...or what about tack welding the spider gears? I know that when I turn my tires will chirp and hop I guesss...should I just invest in a solid unit? What's the best for 1/4 mile performance?
Thanks guys!
Statcher1
Kentucky
The best for a 1/4 mile drag will be welded gears with some sticky tires. But you are sacrificing drive ability with welded gears.
R
ramchrisfla
5.9 Magnum
Probably impractical, kind of thought so....otherwise more people would do it. Just thought I'd ask
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
The weld spiders is called a "Lincoln Locker". You might consider a "Lunch Box" locker instead.
Crescent1101
Tampa, FL
3.0L ECODIESEL
Can someone explain to a dummy what a lunch box locker is? I can't get the sites to load for me when I googled it.
Redtruck-VA
Virginia
