A Spare Tire ? :O
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
A stupid ?
Planning on changing my never used 11 y/o Good Year SRA tire this summer only because of age !
I will sand the rim and paint !
I read a few places that the spare has a TPMS that will work after install and driving so will see lol
Planning on a Budget tire as I can not see paying 200$ for the spare but will lol
Tire PSI is 40 PSI' Does it make sense to set the spare at 45/50 psi since in may get checked once a year
What budget tires have you used ?
star_deceiver
Airdrie, Alberta
3.6 Pentastar
I went online and found an old rim with a 7 year old sr-a for $50. Took it with me for the Dempster trip last year.
If I’m home and need something for a day or two I’ll just put on one of the studded winters.
Realistically, unless your rock crawling, buy the cheapest tire. It only needs to exist and work.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
A stupid ?
Yes, the full size spares do come with a TPMS sensor, well most do, anyway.
The TPMS on the spare will not show up anywhere on the EVIC, but will show pressure low and won't tell you it's the spare. Pretty dumb idea.
Ask me how I know this... Just went through it and was stumped till I discovered this "undocumented feature". I changed the spare sensor ( new Autel one) with a programmed new one (Have an Autel MAX TPMS3501 Pro TPMS tool), then did an RF hub reset and all is good now.
There is a setting in AlfaOBD that changes sensors from 4 to 5 sensors or visa versa (with or without the full size spare TPS).
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thank You all for your replies !
I will find out in a few weeks if it has a TPMS LOL
Info online has been mixed !
mtofell
My 2014 HD spare didn't register on my EVIC. Just went through this and wasn't sure either.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
LOL, like all the websites that say to push the reset button, left side of steering column. Yeah, the button that doesn't exist.
So much clarity on the web.
I will have to look to see if that button is not there lol
Yea web info can be hit or miss :O
grizzstang
Calgary, Alberta Canada
My Ram came with the Doughnut Spare which I didn't love since I tow a travel trailer in the summer months.
I went to the dealer and picked up a 20" Ram steel wheel about a year after I bought my truck and the cost was not too bad at that time.
No cheap spare tire though I went a little larger when I got rid of the stock tires so I put the same on my spare.
RamDiver
Marlborough, Ontario Canada
2021 DS
My new Ram 2500 Limited came with 20” tires on the ground….and a “Full Size Spare”…. which when I checked it…. the spare is actually an 18” wheel and tire. :mad:
Mine is called a "full-sized temporary spare" for 50 mph maximum, IIRC.
The tread makes the stock 'good for a year' OE tires look good.
I had them install the new tires on the traded Tundra and use my preferred tires on the Ram truck.
My truck came with 20" Al rims, but the spare is a 17" oddball-sized tire.
gen 4, 5-bolt sized.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
My tires are 265/70/17 and came with Goodyear SRA tires the spare is the same that was on my RAM but on a steel rim !
I am going to drop the spare and wire brush the rim the paint with Rust stop primer/paint then while tire down will spray Fluid Film on the tire winch !
jc56berg
houston, TX
O.K. so I take it that I could replace my doughnut spare with a 20 inch full size spare? I really don't like that punny little thing. Bought new, 20's were in the Lstar pac'g.
4xdad
Edmonton Alberta
2015 powerwagon
35s and i didn’t like where it stored so i built my own. the red box contains a little diesel heater the jerrycan has the fuel. the battery is in the canopy. 2 actually
Dean2
Near Edmonton
I have 5 matching wheels, the best of the tires getting changed is always the new spare.
That is what I do too, except my spare rim is an OEM factory steel one.
If I was the OP, I would just wait till I needed new tires again. In 11 years his current spare has likely never been used.
Napabandit
Napa, CA
I bought a used rim from eBay and removed the chrome cover and adhesive foam. I put my best old tire on it when I got new tires. The rim was $50, mounting it was $30.
You have to remove the chrome cover to fit the spare tire clamp through the hole. Kind of a pain to do, but I did it while sipping a couple of beers in the shade.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
First WELCOME to the group !
Did not know that about the OEM wheel Thanks
grizzstang
Sure can. I am also running larger LT275/65R20's that are about one inch taller than stock and it still fits under the bed.
I do have an extra strap across the bottom to support the extra weight of the new setup for my own peace of mind but I am sure the stock hanger could handle it.
