Advice from DSP users
BigMike005
Miami, FL
I saw today on my DSP, there is an option on throttle response.... what are you guy putting it on....how much do i increase?, if i should....
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Way out of my league smarty ;) good luck someone will know.
Sent from my Verizon iPhone
$miley
mitchman
SC
I haven't changed mine from the original setting haha
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Intrested to hear bout this also, the fly by wire is slow IMO.
truckin151
2013 sport
I had mine set to 10 and it felt great, anything higher and it felt to touchy. If you have a ported TB DO NOT go above 10, it becomes way to sensitive.
If you are custom tuned, I believe the TB sensitivity is already increased so increasing it more might be an issue. I know right now with my tune, if I increase it another 1-2 settings it makes the truck act funky.
I would go to 10, see how you like it and then increase it by 1-2 from there til it feels off, then back it down 1.
B
BigMike005
Miami, FL
when i went to modify it, it was set on 0....so i jus brought it up to 2...runs pretty nice.....
truckin151
2013 sport
Right it will start on 0, 1 through around 6 I didnt feeel much of anything over the performance tune file, above 6 It started feeling better and best around 10 before it started acting up with my ported TB.
glass3222
Central PA
When I ran mine, I tried everything. 20 was very touchy. I found 8 to be the best for me with my ported TB. It felt the closest to a cable driven throttle getting rid of most (but not all) of the drive by wire feel. When I removed the ported TB I bupmped it up to 12 to get the same feel.
