AF vs SilverBullet Showdown
AF or Silverbullet
  • AF
    Votes: 22 66.7%
  • Silverbullet
    Votes: 11 33.3%
  • Total voters
    33
S
Silverbullet08
Persona Non Grata
well i might try to put the valve covers back on today but i dont get out of class till 7. then i got to find a way back to my parents house. man i feel like im 15 again with no truck lol
sawcut64
Arlington/DFW Texas
Like I've been telling you all along bro I think the problem is in the exhaust somewhere.....just bring the sensor over to my house and I'll check it out for you.
S
Silverbullet08
Persona Non Grata
txt me when your available and location so i can see when i cant get a ride and ill bring it over...
i agree the problem is with the exhaust. i just wanted to check the rods to make sure and rule that completely out...
sawcut64
Arlington/DFW Texas
Yeah I agree it was wise to check them. You have list of potential problems and now you're checking them off the list!
S
Silverbullet08
Persona Non Grata
just put everything back together. got a new sensor thanks to sam. still does the same thing...
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
just got off the phone with nick.
he got a new o2 sensor from sam and the problem still exists.
so far we've eliminated push rod, and o2 sensor. im also still very confident we can eliminate timing chain.
nick is going to get some short universal exhaust pipe to hook up to the headers in an effort to eliminate the possibility of the o2 sensing too much oxygen because its so close to the tip of the headers. he'll also be checking the rest of the fuses.
what are your thoughts guys? whats next?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Any lines not reconnected causing a massive vac leak?
sawcut64
Arlington/DFW Texas
There are two vacuum lines right behind the throttle body. How about all the lines that are right next to the drivers side header, how close are they to the header itself? If it were me the next thing I would do is finish the exhaust. Drive it to the muffler shop as best as you can to rule that out.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
There is just so much stuff that got tweaked and changed. Current sit is the truck will not even run in part correct?... we have elemed the 02s and pushrods so far.
S
Silverbullet08
Persona Non Grata
yes wont run in park. starts and then stalls out...
i really need this fixed by this weekend. i just got a job today...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
If the vac lines behind the TB are not split or damaged then that elems most of the stuff in the engine bay motor related. The new battery being in I would do a hard dump on the PCM and try reloading the tune and see where that could lead ya. With the wrench shorting out the wires it coulda back fed into the PCM. Do yall know what wires were damaged?
AF_Hemi
i never disconnected the throttle body. never touched the tubes back there (which is why i didnt mention them).
who knows what got damaged with the short. just cause stuff isnt burnt doesnt mean its not damaged.
Pocho808
