Hey guys I'm hoping maybe you can help me with this. I installed the single zone ATC from
@Mpgrimm2 along with the cabin temp sensor. Using Alfaobd, activated the dual zone ATC, waited 10 mins, then single zone ATC, waited 10 mins. Now it shows the proper 1 temp slider with a temp setting but it won't go into defrost from dash vents or vice versa. If you turn it off and on sometimes it works. Also if you move the temp slider all the way hot to cold it starts working for awhile. I ran the actuator calibration test and it's looking for the second zone temp actuator which isn't there in my truck. It's also pulling an error for that as well. Its almost like it didn't fully take the single zone ATC from the Alfa. Any ideas? Bring it back to single zone MTC and try again?
My truck is a 2013 1500 Bighorn with factory RA3 and 7 position fan control. In Alfa there's 2 separate MY2013 Body Modules to select from so not sure if that makes a difference either...
Thanks for any help!
