Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
AlfaOBD
Discussion in '4th Gen DIY' started by Ghost_RAM, Jul 30, 2018.
  1. Caterpillar
    Caterpillar Member
    59
    52
    35
    Dec 26, 2020
    France
    Ram Year:
    Rebel 2016
    Engine:
    Thank you Manuel but everyone here has bought some and there is none !!!!!!! I will have to wait
  2. Cuong Ly
    Cuong Ly Junior Member
    30
    Mar 25, 2021
    Philadelphia, PA
    Ram Year:
    Engine:
    Diesel 6.7L
    Can someone help me program my keyless entry on my 2011 2500?
    When I brought the truck a few months ago. It only came with they single key to the left.
    I ordered two OEM keyless fobs
    The problem is when I get to the last step “ PROGRAM IGNITION KEYS or KEYS FOBS “. It gets stuck at started please wait.
    My procedures. I inserted my original key into the ignition. I turned it to run position.
    I connected my android phone>Bluetooth>Alfaobd.
    when I get to “PROGRAM IGNITION KEYS or KEYS FOBS”
    I turn the truck off, remove the original key.
    Insert the new FOB
    Turn the ignition to ACC
    I enter my 4 digit pin
    And I hit start.
    and it just hangs there.
    tnctx02 likes this.
  3. Caterpillar
    Caterpillar Member
    59
    52
    35
    Dec 26, 2020
    France
    Ram Year:
    Rebel 2016
    Engine:
  4. chrisbh17
    chrisbh17 Senior Member
    6,631
    7,302
    Oct 12, 2017
    Ram Year:
    Engine:
    If its already programmed it needs to be cleared before it can be reprogrammed. Only a dealer or locksmith (with presumably expensive tools) can do that.
    Stick with new, even if you have to buy a generic brand (I had good luck with KeylessOption on Amazon)
    Caterpillar likes this.
  5. jlsalani
    jlsalani Member
    59
    51
    21
    Jan 25, 2015
    Ram Year:
    Engine:
    I have what might be a silly question... just had my CEL go on and then right after that a cluster notification that my left tail light was out. Replaced the tail light and then used Alpha OBD to check the code.. got B1642, tail light short to ground... cleared the code and now there are none left, but the CEL will not go away?... is there something I am doing wrong?, or does it take key cycles after I clear the code before it goes away? I have had other OBD SW that when I cleared the code it turned off right away.
    ..... and is that normal to have to have a CEL light up with a tail lamp being out?
    SitKneelBend likes this.
  6. Jimmy07
    Jimmy07 Senior Member
    2,879
    2,367
    Feb 23, 2017
    Ram Year:
    Engine:
    There is some other issue going on. Most faults in the BCM don’t request a CEL, and definitely not lamp faults. Check all the other modules for faults, starting with the engine.
    likes2build and SitKneelBend like this.
  7. jlsalani
    jlsalani Member
    59
    51
    21
    Jan 25, 2015
    Ram Year:
    Engine:
    ahhh.... think I get it now. I thought that all codes were shown regardless of module. What are the major ones for codes, engine for sure, and body controller... any others?
    looks like it was just a coincidence that I got a CEL and tail lamp out at the same time!.. next work break will go check again. Thanks.
  8. alpinegreenneon
    alpinegreenneon Senior Member
    74
    136
    154
    Mar 19, 2018
    Northwest Wisconsin
    Ram Year:
    Engine:
    3.6
  9. Jimmy07
    2,879
    2,367
    Feb 23, 2017
    Ram Year:
    Engine:
    Someone posted in the Chrysler pin puller thread about a month or so ago that he received a test version from Alexey, and it worked for Rams, so definitely sounds like he got it dialed in.
    *edit* I see you mentioned in the linked thread about the same post I probably saw.
  10. NicksGarage
    NicksGarage Member
    45
    36
    Apr 15, 2021
    Ramona, CA
    Ram Year:
    2009
    Engine:
    5.7L
Share This Page
