AlfaOBD
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Nice!
Are you adding in a CD player? Or swapping the console?
We added the console and the console mounted CD player to it. This truck is a Tradesman with no factory options other then a tow package and the Hemi.
Ramsportrocks
east gabip
my express came with the chrome capped mirrors..
what are the odds that they have tilt in reverse capability?
Morgan
Ontario
Ecodiesel
It might take the night to have the changes take effect. I waited more than 20 minutes for DRL's and the fog light drop out to work. And the LED turn/park lights too. It took a day or better for the DRL to show in the settings in the Lights on the 8.4's screen.
Im wondering if maybe the wait times can be improved. Do you think pulling the negative battery terminal after we have applied all settings changes would force everything to reboot with the new configuration settings?
kad
Hudson Valley, NY
5.7L HEMI
It should. But the whole wait time thing is widely variable between trucks. I've done many changes to mine and the only one I've ever had to wait longer than the minute or so that it takes the cluster to go dark was turning on the cargo camera input.
-K
Ricks Ram
Did you buy your truck new? I have never seen an Express with chrome capped blinker/puddle light mirrors or any other mirror except the basic heated mirrors from the factory. If you have blinker/puddle lights in your mirrors and they are chrome capped they were most likely added by the dealer or previous owner. If you have non blinker/puddle light mirrors with the chrome cap that is something that was added aftermarket and its just a stick on cover. All that said if somehow you ended up with factory chrome capped blinker/puddle light mirrors there is a chance they are memory mirrors. You can check for sure by removing the door panel and counting the wires in the white mirror connector. If you have more than four mirrors in the white mirror connector they are memory mirrors.
GordDavey
Toronto, Ontario
Need some help with turn signal hyper-flash in EVIC.
Situation, truck has analogue front lights and taillights. The BCM came from a sport which had led's front and rear and projectors.
I'm getting a front and rear left turn signal bulb out warning & code. But both the left front and left rear turn signals operate normally and flash at normal speed. However the codes show up in the OBD and the 7" EVIC says there is a lamp fault for those two, and the left turn signal within the EVIC hyper-flashes.
The right front and right rear are fine, and have no codes, nor warnings and they work properly.
Since from the BCM's point of view this is a "downgrade", I'm wondering what BCM settings would be changed/involved for this. I'm sure I've got all the led items turned off, but it's always possible I've missed something, or there is a non-obvious setting.
Any advice on what settings I can check for this ? If I had to guess I would say that it is looking for canbus messages for those two lights (front and rear) and of course it is not wired for the leds.
Jimmy07
Did you turn off the front and rear fault detection circuits that are normally enabled on the led trucks? There are four of them under CBC I/O Usage:
Driver door ajar switch usage > disable
Front passenger door ajar switch usage > disable
Left rear door ajar switch usage > disable
Right rear door ajar switch usage > disable
I know it doesn’t sound right being “door ajar”, but you’ll see once you select value that they are the lamp diagnostics circuits that are normally disabled on non led light trucks.
Ramsportrocks
east gabip
I am 2nd owner but met original owner and he said it came how I bought it with the exception of the mopar vent visors which he had dealer install before he picked it up.. it does not have blinker/puddle
aimvee
CA
When changing the tire pressure threshold.. what exactly does that mean?
For example. If I set the Threshold at 28 PSI the warning will not come on until under that?
I have a friend that likes to over air when pulling his camper. So what should it be set at?
Sent from my SM-G965W using Tapatalk
horsetrailer
6.4 Hemi Power Wagon
That's what I did. Took a while to boot but it came right up
Sent from my Pixel 2 using Tapatalk
Bama_ram_1500
Alabama
I have a 2500 and from the factory mine was set for 65 psi front and 80 psi rear. I run 55 in mine when not pulling a load so I set mine to 50 both front and rear.
aimvee
CA
I did 14 changes on a 2016 EcoDiesel.
Including Auto high beams and tilt in reverse. Both of those showed up in the 5-inch right away all of the other changes I waited anywhere between three and five minutes. I can only assume they were pretty instant
GordDavey
Toronto, Ontario
Jimmy07,
No I didn’t. I wouldn’t have guessed those. I’ll give them a try and see what happens. Thanks very much.
dracman
canada
2011 ram 1500 reg cab.dads ol truck
I got my sport mirrors working and did global down.i did the upper glove box and now trying to get light to work has anyone do this one .thanks dave
kad
Hudson Valley, NY
5.7L HEMI
The glove box light? As far as I've read, that one "just works", there are no settings for it. You just plug the light unit into the plug that's already there and you're done.
-K
GordDavey
Toronto, Ontario
Jimmy07, Just to confirm, changing these 4 settings has resolved my issue. The turn signals flash correctly, the turn signals in the EVIC no longer hyperflash, and the bulb out messages have gone. All 4 were set to Jeep/Truck and now they are set to disabled.
Thank you very much.
Morgan
Ontario
Ecodiesel
Hey everyone so far I've had great success with alpha. I have successfully enabled optional drl via uconnect interface.
Global down.
Fogs with high beams.
Tried my luck with mirror auto tilt in reverse but it seems I dont have the correct mirrors. W/e i knew it was a long shot.
Would it be possible to have tail lights on with ignition via alphaobd?
Sent from my SM-G955W using Tapatalk
GordDavey
Toronto, Ontario
One more question for you Jimmy07, the VIN WRITE in the BCM config. Is there anything special about how to do it? I'm assuming you just input the entire VIN and hit start.
I thought I would ask you, since your name is on the earlier posts about the vin write being possible.
