AlfaOBD
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
We get ahold of him by email. With the current world turmoil there is no telling how quickly he can or will respond.
Tepco
North Carolina
For those fighting to get your odometer to stop flashing with a proxi alignment on a Pro master City, keep your radio on.
I done a proxy alignment, several times with no solution, radio off. I found an article about having trouble, they tried with the radio off like me, didn't work. Tried with it on and bam done. I tried it and it worked!
I was so relieved, no more annoying flashing odometer.
SSCBryce
So, trying to disable the TPMS with AlphOBD on a 2014 Ram. Did this 3 times, but each time it pops back on as soon as I shut down AlphaOBD and unplug. The original reason I want to disable it is because the TPMS light stays on even though it is reading the correct pressure and when I manually check the tire psi it is correct to the dash.
oh, and we are using a Veepeak OBDCheck BLE Bluetooth OBD II Scanner.
Thoughts?
pullup
ohio
I've been using this dongle. Works for everything so far. OBDLink LX OBD2 Bluetooth Scanner, the green one. Auto down windows, Trans relearn, fogs with highbeams, factory trailer brake controller install, load screen on uconnect, lowered tpms value.
hilo
Cloud
I installed DRL LED, enabled all LED and DRL settings, and got it to run. But I don’t think I have the fault sensing cables. I remember reading on this thread that you don’t need the fault sensing cables for the LED DRL to operate. If my LED DRL stops working one day, does that mean that I won’t be ever be notified on the dash about a bad turn signal?
Paperboy4828
Upstate, NY
I posted this in a different forum topic, but figured I'd copy it here: So, I have a question. I ordered two new blank key fobs from e-bay and used Alfaodb to program them. All four (the two original and the two I programmed) work fine in all functions on my 2014 RAM 2500. Recently a jacket (with one of the key fobs in the pocket) was stolen. I'm pissed about the jacket, but more concerned about the key fob. I take the truck to the place the jacket was stolen often, and I'm concerned the perp will take the truck. I can have the door locks changed, but short of a new BCM, can I delete all the keys and program another set of new ones so all four of the existing will be useless? Thanks.
TRad
Minnesota
Need some help... Changed tires to 275-60x20's and went in to AfphaOBD to change tire size. It accepted the tire size, but then when I try to initialize the ABS..... the START button isn't live. It is just 'grayed' out.
What do I need to do?
I have a 2014 with a GDE ECU tune.
The Start button will never enable. It is just telling you how to do it. Read the directions and complete both tasks to initialize your ABS. I was confused the first time i tried it. Good luck.
This worked for me...
Start off with key in Run position
Open App
Select Body Computer and select Connect
Select Hood Icon
Select “Program Tire Size”
Enter tire size and hit Start
Back out to main page…
Cycle Key
Select ABS
Select ABS control unit Continental and select connect
Select hood icon
Select ECU Initialization
Hit Start
Select Check Engine and clear faults
Cycle Key
Select hood icon
Select “Clear Rolls Information”
Hit Start
Clear Fault from the Body Computer and the Engine Computer
Back to main page
Cycle Key…..
Good Luck!!
BearlyFunctioning
Has anyone adjusted any of the ESC settings using AlfaOBD?
I have found when having way too much fun power sliding all four tires around an asphalt corner at 45ish in my PowerWagon, even with the stability control switched off, I can still manage to get the ESC light to come on and kill my throttle.
It takes a lot to do it, but there is a little more slide left in it if the throttle would not give up.
Thanks.
UtterlyDodgy
Bozeman, MT
6.7L V6
I hate to sound like my ******** self, but can someone please point me to the EXACT sequence of menu options to force my '16 Cummins 2500 to regen? As deep as these AlfaOBD menus go, I'm not down for ******** around and trial/erroring this...
Thank you in advance!
Devildog8791
Lonoke, AR
Has anyone had a problem applying changes to VehConfig 3? I am trying to change the HVAC Configuration, but I don't think it is actually changing anything. I have changed it to Dual Zone ATC, but when I upload to Google Drive, it still shows me on Single Zone ATC. I never get the "Procedure Completed" message after making changes either.
Highway
Ky
Went by the dealer and got my 4 digit pin code. Parts guy behind the counter said it was temporary and would expire probably by tomorrow , is that correct? I thought it was a permanent pin and changed only went you go back to dealer to get another pin.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
If you’re talking about the RF hub pin then no that’s not correct. It’s the pin for the life of the unit.
Highway
Ky
anyone have a problem with payment. I bought a preloaded card to use online and it says card declined. So i linked the card to my paypal after checking the balance and i tried using paypal and same thing declined. There is enough on the card to cover the purchase
Highway
Ky
Got it, guess it took a little more time for card to activate than i had figured
Highway
Ky
Using laptop/windows, how do i make a backup of my original settings BCM ?
