AlfaOBD
1500ram12
5.9L Cummins
So I have these headlight and I’m getting lamp out message when the headlights are on because these are switch backs. So the white led goes out. Any idea how to correct with alfaobd? I have already changed settings for led turn signals and led park lamps but still get the message. See
YouTube link.
Did your truck originally come with projector headlights?
If no
Try the settings that I had r84boomer do originally. If you still get an error than change turn to no and parking to yes
2018 Ram 2500 6.4L Hemi Tradesman
chrisbh17
These are my current settings. While I have a modified set of Gen 1, they seem to be pretty close to Gen 2 in operation.
I do not get a parking light out error. I do get a turn signal out error ONLY if the turn signals are on at the same time the headlights come on (i.e. if you have auto headlights on and it gets dark enough for them to come on automatically). Have not been able to fix that auto-on issue, but with headlights off, or if they are already on when you start signalling, I get no errors. Note that I have factory LED taillights as well, so ignore my rear and taillight settings if you do not.
CBC Exterior Lighting Calibrations:
Auto Headlamp ON Threshold: 3.31 V
Auto Headlamp OFF Threshold: 2.55 V
Left Side DRL Voltage Target: 12.2 V
Right Side DRL Voltage Target: 12.2 V
Left Low Beam Voltage Regulation: 12.2 V
Left High Beam Voltage Regulation: 12.2 V
Right Low Beam Voltage Regulation: 12.2 V
Right High Beam Voltage Regulation: 12.2 V
Left Front Corner Voltage: 12.2V
Right Front Corner Voltage: 12.2 V
Left Rear Corner Voltage: 12.2 V
Right Rear Corner Voltage: 12.2 V
DRL Configuration: Optional DRL
DRL Lamp Location: Dedicated
DRL Dropout Enable: Set
Tunnel Detection: Not set
Rear Lighting DTC Disable: Not set
LED Reverse Lamps Present: Set
LED Stop Lamps Present: Set
LED Rear Turn Lamps Present: Set
LED Tail Lamps Present: Set
LED Rear Fog Lamps Present: Not set
LED License Lamps Present: Set
LED Front Turn Lamps Present: Set
LED Front Fog Lamps Present: Not set
LED Dedicated DRL Present: Set
LED Low Beam Lamps Present: Not set
LED High Beam Lamps Present: Not set
LED Front Park/Marker Lamps Present: Set
Imprtkllrz28
Adelanto, CA
If no
That worked thank you
Superj
AZ
Hi
Is there any procedure on how to turn on DRL on a RAM 1500 (2012)?
If possible, I would like to activate the Fog lights as DRLs.
I found all kind of descriptions for 2013+ trucks but not for 2012.
Any hint welcome.
1500ram12
5.9L Cummins
Hi
Any hint welcome.
I believe so. There is a alphaobd thread for 06-12 truck's
Ramshig
HEMI 5.7
Just installed a new evic 7 in from a 2014 into a 2015 everything works I was able to program the milage with alfa obd but I have a slight problem it is stuck on the milage I programmed and same with the trip and the oil change indicator.. Any ideas ?
jimlmackjr
Harker Height, TX
i cant help but Ive been trying the similar thing
did you have to use aphaobd to have the truck to see the 7inch Evic screen
ive tired several time to get my mileage and still wont change
i have a 2013 (i was told Evic 7") im using Veepeak obd with the lastest Alpha
i know it works ive done
*global window down
*changed tire size
*activated my over head garage door controler
RockyAEV
Please forgive me if this has already been asked, I looked through everything and did not see this question.
I have diode Dynamics switch backs for my turn signals, I have turned on my DRL with ALFAOBDand told it to set the DRL to turn signals, however it comes on on a different voltage and does not activate the white side of the switch backs. Is there a way to make this work?
Problem- I want my DRL to be the white on my turn signal switch backs, but the DRL only activates the amber side of the bulb.
2018 Ram 2500 Tradesman
6.7L, G56
Jimmy07
6.7L, G56
You can’t set DRLs as turn signals for switchbacks, because that’s what will end up being the DRLs....the amber turn signals. These are the settings you need:
DRL configuration >optional
DRL lamp location > dedicated
DRL dropout enabled > yes
CBC I/O right dedicated DRL lamp output present> yes (should be yes already)
CBC I/O left dedicated DRL lamp output present > yes (should be yes already)
LED dedicated DRL present> yes
ECUConfig 3 DRL customer setting enable> yes
CustSetMenu 1 daytime running lights CSM> yes
RockyAEV
Well dang, ok that’s what I have set up now. Guess I’ll change it back to headlights and look at my options for LED’s ....just never been happy with LED’s for my headlights...but I like the look it gives the truck
6.7L, G56
Jimmy07
6.7L, G56
Do you have the red wire from the DD drivers tapped into the truck’s dedicated DRL wire? That’s the only way it will work like this. Vrwv2YB.jpg
RockyAEV
Ha nope, I have the poor man’s headlights....just the bulb installed. I would love to upgrade to the projector style headlights but can’t just yet on my truck....doing a few more things to the wife’s first.
6.7L, G56
Jimmy07
6.7L, G56
Ahh, sorry. Every time I here DD switchbacks, I automatically think of their boards and forget about the bulbs. You can still make it happen with those settings, but you have to add the dedicated DRL wires and tap them into the parking light wires with diodes.
Ramshig
HEMI 5.7
Is there any way to get the vehicle settings option to pop up on a 2014 7 in evic. I have the tesla screen by linkswell. I read you need to enable IPC ECU config 4 but no joy. Please advise.
noraa73
