AlfaOBD
Shugarrckbx
Must be a communication error in my opinion between the two. Would a canbus reset help? Infotainment said to give that a try, your thoughts?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If you're asking me I'm not sure what a CANBUS reset is but disconnecting power resets everything...
Ricks Ram
Maybe the key is to have a 16’ or newer radio???
No I have had several radios. I had a 13, 14, 15 and a 16 and they have all worked fine. If there is any problem it's most likely the speedometer.
Shugarrckbx
They say a canbus reset is close doors disconnect the battery,touch the neg and post together for 15 secs. Let sit for 20 mins, then reconnect and let sit another 15 mins, resets the truck...
Shugarrckbx
I did a speedo self check test, come back good
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Good to know. You can give it a try. I'll PM you my original backup of my settings before changing anything in Alfa for my 2014 Express. Maybe you can bounce it off your settings to see if something sticks out...
Shugarrckbx
Does your evic show nav pop up turn by turn in the menu setting area like ,display fuel saver, lights on with wiper etc..
Shugarrckbx
Ok, great thank you!
stimpy433
IOWA
Well then, I’m all out of ideas.... hahaha!!! I’ll have to try it again this weekend, but I’ll upgrade my AlfaOBD to see if that has any effect.
stimpy433
IOWA
I have a 2014 RA4 and a 2014 premium cluster both added after the fact and turn by turn works in the cluster.
Can you post a picture of what the radio setting screen with the turn by turn looks like on your radio so I can compare it to mine...
Shugarrckbx
Hey I got it! Thank you! A lot to compare, I'll go bug eyed going over all this! Lol
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
There are apps out there you can use to compare the text to your own. A free code compare tool should do the trick I think.
Maybe this one?
Diffchecker.com
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Are you asking about a specific menu in the radio or the cluster? If radio I currently have a newer UAS without NAV installed but I can check in a couple days when I replace the touchscreen with my RA4.
If you mean the settings in the EVIC, I was never able to get them to appear in the cluster. Maybe that's the difference?
