AlfaOBD
dwalk19
NY
cummins 6.7
Verify that the hour's hasn't changed. It seems although the app will say it failed it indeed did change the hour's
2018 Ram 2500 6.4L Hemi Tradesman
Yeah mine doesn't seem to be changing and I think not sure yet but I think the EVIC is not turning off when I leave the truck
Sent from my SM-G960U1 using Tapatalk
dwalk19
NY
cummins 6.7
Ok evic turned off, but gotta figure out why hours are not changing issues
chri5k
USA
Diesel
Check post 1 of this thread. There are some links on changing mileage and hours near the bottom of the known working list.
dwalk19
NY
cummins 6.7
I just read it, only thing I see to do different is changing them both in succession and then powering down , I'll try that next
yerfttam
Austin, Tx
6.7 cummins
Hi Everyone-
Hoping someone can help.
2013 2500 with the 6.7
I am trying to turn off the TPMS and turn on the TPIS, like the 3500’s.
I set Base TPMS and Premium TPMS to “no.”
I set Non-Regulated TPIS to “yes.”
I then used my pin to reset the RF Hub.
In the EVIC, the “Service TPMS” message goes away and I can no longer see tire pressures in the menus.
All that’s fine and good........but the stupid flat tire light is still on.
Anyone have any ideas?
I’ve had success doing things like leaving the fogs on with the brights and setting my tire size.....just can’t crack this one.
I greatly appreciate any ideas.
Thank You!!!
Bumping this post back up. Can anyone help? Thank you!!
yerfttam
Austin, Tx
6.7 cummins
Did you check post 1? I believe there is something on changing to a different tpms. If not I believe on cumminsforum there is
Yes, I followed the directions exactly as listed.
1500ram12
5.9L Cummins
I don't know if you have to lower the pressure threshold or not
or it's possible that the light needs to be off prior to changing tpms types
yerfttam
Austin, Tx
6.7 cummins
I tried lowering the pressure.
I think you may be right about the light needing to be off prior to switching to TPIS.
dwalk19
NY
cummins 6.7
I’ve been running into the same issue. What obd are you using?
I bought the mx bluetooth adapter and this is the version I have of alphaobd,,,
P.s I was able to do the tpms reset by using directions from a YouTube video,, no issues doing that just got mileage change also but can't get engine/lifetime hours to change2998bc5e6e719ac4c9029dc7c64d6b63.jpg
Sdpadrez
Are you using android phone or laptop?
dwalk19
NY
cummins 6.7
I tried both, couldn't get it to connect were with body computer from phone, but it would connect on Samsung tablet and that's how I changed mileage
1500ram12
5.9L Cummins
I don't know if it's a year truck or year cluster issue with alfaobd and mileage or hour correction but other's have said that it took a few tries to take. If you could, in the 4th gen diy section I have a thread about mileage and hours correction notes. Could you post your info and results in that thread. The more results could show a possible bug with certain year truck/cluster combos
Sdpadrez
I was able to change my mileage just fine. First try. It’s my idle and hours that don’t work. I have been in contact with alexey and him and his partner are working to solve the issue. There have been several requests to get this fixed. So for now just hold tight OR keep trying.
1500ram12
5.9L Cummins
Could you post your truck info and cluster in the 4th gen diy section on the mileage correction notes thread. The results could help Alexey in fixing these issues
Sdpadrez
I literally just mentioned that I have already been In contact with Alexey and him and his partner are working on a solution.
KAKA
