Anybody running Redline in trans and diffs?
Inside Man
N.E. Ohio
After switching to Redline motor oil the feel and the sound of my truck makes me a believer. Is anybody running the trans fluid in there ram? What about in the diffs. I'm thinking of doing this and I've read some good reviews online about there trans and diffs being a lot smoother.
HLram
2012 and 2007
Hemi 5.7 in both
I asked my oil change guy to order me some redline for my engine, so I will try it next oil change. If it really works then I may try it elsewhere on the truck.
Talon_66
Deadmonton
In my 2010, I used it in my front and rear diff.
Previous to that I ran it pretty much exclusively in my Evo X
Burla
2010 Hemi Reg Cab 4x4
Soon as I can I will, but I'm trying to figure out how to get all of the oil out of the Torque Convertor. They really screw us on having the ability to empty the trans fluid and then replace. It isn't that simple at all.
jsl6v8
Virginia Beach for the moment
2013 Ram 1500 HFE RCSB
3.6L V6 And proud.
I'm sorry can you explain that? Just trying to get a better understanding of how things work.
Burla
From Dirty Dog on other dodge forum.
DIY Transmission flush
Many of you are wondering how to do a transmission flush/exchange without hurting the trans. Most machines at garages are pressurized and use a cleaning agent to flush the system debris out. This is very bad and breaks free hardened deposits in large chunks that can block very small orifices. Since transmission fluid itself is a cleaning agent, installing fresh fluid will clean the inside's itself..over a very long time and is very safe. Now, there are some that allow the transmission to pump the fluid out itself and use no cleaning agents at all, which is what you really want. Speak with the Service writer or technician and ask if they can Exchange your fluid with no cleaning agents. No cleaning agents unless they'll warranty your trans for damage occurred from the flush!
This is a little explanation on how to do a Transmission flush on your own in your driveway. It takes about an hour for just fresh fluid and about 2hours for a pan frop and filter change.
System contains 17qts of fluid. Plan on Buying 20qts and using 19 if not 20qts. You can't expect to get all old fluid out if you just use 17qts. Not gonna work. Dont be cheap and spend the extra $25 on 3 more qts and do it right.
Procedure:
First off, there is a T-stat located in the return line from the cooler so you either have to do this at operating temperature so the tstat allows flow, or pull off the supply line at the cooler if you want to do it when cold.
1) Lay down a large piece of cardboard under the truck. Overlap pieces if you must. The carboard will absorb any splashes or sprays that may occur and makes clean-up a breeze!
2) Unhook the return line of the transmission if hot, or the supply line to the cooler. This is the one at the bottom of the trans closest to the pan. I've included a pic below to show you.
3) Once the return line is disconnected, you'll want to place a rubber hose(probably 3/8" inside diameter over the flare fitting. You'll put the other end of the rubber hose into a bucket.
4) Start the truck up and let it idle until the fluid starts to spit/sputter for a few seconds. Then turn the truck off. Now, your trans pan is almost empty and the only remaining fluid left is what couldn't be sucked up through your filter.
5) Now is when you remove your pan and do your filter change. The pan will probably have a little less than 1qt of fluid in it so be careful when removing it. It beats having 7qts dumped on you without following this procedure!!
6) When you get the filter chane and pan all wiped out and all buttoned back up, your going to pour in 7qts of fresh ATF+4. Don't even worry about the dipstick, just leave it out.
7) You'll start your truck again and this time put in gear for only 5sec then go back in park. Let it run until the fluid spits/sputters. Then turn it off.
8) At this point, you pushed out and emptied ~7qts before filter change. You've just pushed out another 6qts with the new fresh fluid(remember there is still ~1qt remaining in pan that filter cannot suck up). That leaves ~4qts of old fluid left plus maybe another 1 or 2qts of flui that has mixed during the process.
9) Pour in 6qts of ATF+4 and run until fluid sputters again.
10) re-install your return line and clean up your mess.
11) Pour in 5qts of fluid and let truck fully warm up. Top off as needed. You'll probably need another 1qt, but it's better to underfill than overfill at this point, granted your not jumping in and driving it around while it's low. It wont hurt anything to be low and idling. Otherwise, you'll have to pop off your retrun line and drain some.
That's it. Your done! This procedure using the transmission pump to regulate the fluid through the transmission and only flows clean fluid through your new filter. I'd reccomend doing this at 50kmi(fluid flush only) and again at 100kmi(fluid and filter change)
I've done this MANY times and never had any problems. I recently did it on a 120kmi Buick that shifted sloppy and then was super smooth afterwards. Did it again on my new beater with 60kmi with same results! Shifts fantastic afterwards. If there's any sludge or what not inside that the fresh fluid breaks down, the new filter has plenty of capacity to remove it.
If you go through this procedure and have ANY problems shifting or going into gear etc. Pour in a full can of Seafoam and drive it for a few hundred miles or idle for a few hours(and go through the gears) if not able to be driven and then do the whole flush procedure again with fresh fluid. Again, never have I had this problem, but a friend had this done at a garage who used a machine. I told him what to do and afterwards he had a perfect shifting and running transmission. DO NOT use any additives UNLESS you have problems. Also, additives are a patch..meaning temporary solution...not a permanent fix!
Don't be scared, just do it. There's no good reason to let your fluid remain in your transmission because your scared and dont want to do preventative maintenance. The WORSE thing for your trans is old dirty fluid. That WILL cause you problems. Bad and dirty trans fluid cannot dissipate heat. You will fry your clutch packs and break metal components from the excessive heat. FLUSH! I mean...EXCHANGE your fluid. That's all your doing, is an exchange.
A LOT of stories you hear are hearsay from guys who don't know all the specifics or understand how things work when flushing/Exchanging.
**PLEASE NOTE** This is a guide and I will not be held responsible for anything that may happen. Please use responsibly.
Burla
Two other things, if you drop the pan you can get a replacement pan with more volume and a magnetic drain plug, and even better yet get a valve body upgrade and switch valve bodies, the rumor is that is very easy to do once the pan is dropped and is a great mod that will strengthen your tranny.
BlownGP
Houston/Baton Rouge
You could also drop the pan. add fluid, Put on a new pan with a drain plug. Run the truck a few hundred miles. Drop it again, change the fluid. By that time would have gotten most of the old stuff out.
Burla
That's not a bad plan at all either.
Inside Man
Inside Man
N.E. Ohio
Where have you seen valve body upgrades for our trucks? Also, any info on where we can get a pan similar to oem with a drain plug? Can you provide a link for info on what replacing the valve body is going to do for us? I don't know much about these tranny's yet and it scares me to even think about modding. Especially with the warranty factor.
bskl76
Bako, ca
5.7 liter Hemi
Tranny pan
Check out mag-hytec. They have 2 different tranny pans. Either @ 2 or 4 more quarts. The bigger maghytec pan can only be installed if u replaced factory Y pipe. I got the bigger tranny pan tht holds 4 more qts it has magnetic drain plug & made of aluminum.
bskl76
Bako, ca
5.7 liter Hemi
Redline
Running it in my differential, IMO can't tell the difference but I have peace of mind I got the best fluid in there. Got 2 cases redline tranny oil waiting for the swap along with my maghytec pan. Just gonna put few more miles before tranny fluid exchange. Also got case of redline motor oil but have to use up mobile 1 stock. Got redline motor oil for all my dirtbikes & streetbike. Do it, ur hemi will love u. IMHO redline is the ****. Oil is the lifeblood of our vehicles dnt skimp on it.
Burla
Sharadon makes the valve body for the Hemi, I'm not sure if it is ready to go on the 8 speed yet, I dunno. I have the 6 speed and when I drop the pan I'm doing mine. They sell directly to the public or through vendors. I think the problem is they need valve bodies to upgrade, and I'm not sure what the supply situation is like. I think you will be able to get it with a pre 2013 Hemi, worst case you would have to send yours in for them to upgrade as opposed to paying the core charge. Check out their website.
If you want similar to OEM drain pan, just use the OEM drain pan and install a drain plug, there are many kits for this.
C3ntury
2009 Ram 1500 CC Sport
FYI Be ready for a very long wait time if you go to Sharadon; I think I waited at least 4wks from order to product received.
Inside Man
Inside Man
N.E. Ohio
Quick update guys. After running Redline Oil all week, the Hemi is still progressively becoming more quiet, and smooth, especially on cold morning startups. Gas Milage has seem to gone up approx Two miles per gallon so far. I won't be sure of the gas milage until I burn up the rest of this tank. While cruising at a steady speeds, or just sitting there ideling, you can't really tell the motor is running! Very happy with this oil so far! I'm gonna have to wait till the first oil change and send out a sample.
KAKA
