They seem to be setup like actual projectors, and if that is the case the rule is "LEDs for reflectors, HID for projectors".
Not saying I would use whatever HID kit comes with them, but I would be leaning towards and HID setup for these.
When you get yours, could you add some pics of the wiring and such? Curious what other HID kits might work (presumably better quality)
Did you order from alpharex or Amazon?
Sent from my Nexus 6P using Tapatalk
pre wired ones I seen that look about right.
Anyone know, if i buy a anti flicker module and find one that can match up to this wire harness, will I be ok using it outside the lights in line, since I will only possibly get low beams, would the antiflicker mess with the halogen in high beams. Also does anyone know what this connector is. Like is it a 9008 or? I seen some pre wired with connectors, would be nice to just plug in.
View attachment 159994 pre wired ones I seen that look about right.
The connector on the back of the headlight housing don’t relate to bulbs themselves. It’s just the 3-way connector that ram has chosen to deliver the high, low, turn, and park light circuits into the housing. From there they branch of the their respective bulb connectors. The 9008/h13 bulb handles both high and low beam, hence the reason it has three wires. It may just be a coincidence that they happen to look similar to the connectors ram chose to use on their quad housings to truck harness, and I’m not sure if they’re the same or not. Since this housing takes h7 bulbs, you would be looking for an in-line anti-flicker module that has the h7 female connector on one end and the male connector on the other end. The bulb connector is inside the housing, so that’s where any add on harness is going to originate, and depending on how much room is inside the housing, may have to be brought outside the housing depending on it’s size. Most lights, whether hid or led, offer the option to add it’s specific anti flicker module as an add-on item.Anyone know, if i buy a anti flicker module and find one that can match up to this wire harness, will I be ok using it outside the lights in line, since I will only possibly get low beams, would the antiflicker mess with the halogen in high beams. Also does anyone know what this connector is. Like is it a 9008 or? I seen some pre wired with connectors, would be nice to just plug in.
How does one know if the anti-flicker setup is necessary?
Just when I think I have the right idea, the whole lighting thing starts to confuse me again!
If you have alphaobd then all you should have to do is set park/turn to led and if you are going to run hid's set the lows to hid and you should be good to go.
Thanks, thats what I was looking for. I know Alfa at least HELPS in regards to lighting, but if it fixes the "issues" then even better.
I guess I just assume everyone has AlfaOBD by now and no one needs anti flicker, CAN adapters or resistors anymore![]()
No one has documented how they are wired or the harness that comes with them other than getting a possible light out message once in a while. So I'm really hoping that having those settings changed with alphaobd is all it takes. My lights should be here next Friday so I'll take pic's of how it's wired and what the drl harness is like. I'm hoping that the exterior "headlight" connection can easily be changed to match up with the truck's harness with using what came with the truck
Ya, think AlphaObd would be worth it got me. I have leds in rear backup lights and license plate lights and never had a bulb out error. I do notice when I turn truck off the leds got license plate dim down and slowly FIM until they go off, about 2 minutes later. But zero light out issues from those. I seen some katana v7 h7 leds on Amazon for like $40 and look identical to the $170 supernova v4 leds and someone in reviews said they were exactly same leds.
Definitely looking out for what you find.
Since AlphaRex sells them directly (but no HID kit), Id rather order from there to save on tax along with the possibility of buying a better HID kit that will work with them. Just need to find out which (if any) other HID kits will work.
It was a dollar cheaper on Amazon, no sales tax for NY at this point, and ease of returning just incase was the biggest reason I went through Amazon.
Unless it's a funky on off connector inside the housing they use on their own stuff, at this point I think any h7 setup will work. But won't know until I physically have it in my hand.
Did you order with or without the HID kit?
Still debating what color, too. White Big Horn so lots of chrome already on it, maybe just go for chrome headlights too.
