Anyone use 3157 Led's
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Anyone use the 3157 LED Bulb ? That is the number I found so not sure it there are others!
in the rear Tail Lights instead of changing the complete light to LED ?
I would use RED Led's Like I did in the third brake light
I did use 921 Led White light for the reverse
Thanks
hunterdan
SE PA
2019 classic
I'm using them in my truck. I'm on my 3rd set, keep having one drop some leds a d even with alfaobd it triggers a code, which is good since the light was going bad. So, I suggest investing in a decent set of leds instead of cheap crap.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks I book marked the bulbs and will stay away from the low priced ones
KPMH
Chicago Area
Thanks
I've had these for about 2-1/2 years now and they have worked without problem. I did have to install the resistors on the turn signal wire since I was getting the occasional "light not working" message. I've put in LED's all around my truck except front turn signals and am happy with them.
https://www.superbrightleds.com/mor...n-27-smd-led-tower-wedge-retrofit/3557/12873/
Pete
2015 Ram 1500 RWD Tradesman
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Pete
I am trying to avoid the resistor if possible ! I heard if you use the resistor you do not get the bulb out warning at the gauge cluster ! !
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I do not have Alpha OBD and no plans on getting one :O But who knows what I think tomorrow lol
Dinky
Oregon
Another reason to get alfaobd thats #2 I think right?
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Justin33
So diesel leds aren’t a thing now? Trying to find the brightest reverse lights I can? Is there a consensus in here?
nekkidhillbilly
hemi
why not? if you do anything to these trucks its best thing you can have. if not at least find a friend that can do it for you.
