Atl-atl's 2024 Tradesman 2500 Power Wagon "documentation" thread
olyelr
Kewadin MI
Been working on a landscaping project for the last week. Rented a small excavator and skid to play with in the dirt. Had a blast and the truck handled it well. The Thuren dual rate rear coils held up quite well considering they have 15" of travel and ride nicer than stock!
I did have an issue with the trailer brake not functioning correctly that I was never able to sort but thankfully the rental place was only about 5 miles away. I do need to figure out what the deal is with it though. When the trailer was plugged in the truck would recognize it until I put it in drive and the truck would say the trailer is disconnected. Everything seemed to be connected correctly, the truck would recognize that I had a trailer when in park, yet when I put it in drive it would not connect the brake, would not let me choose the trailer type and would not let me set the gain. The brake also would not work using the manual switch. Its my first time towing with this truck so maybe its operator error. If anyone is familiar please help!
I would definitely try another trailer first and see if that gives you the same results. Could have been an issue with the trailer.
A
Atl-atl
Well Ive started doing some prep work on the Ram in anticipation of phase 2. The stock brake pads are horrendous on this truck, especially after going up to 40s. So I decided to try out new pads before blowing a whole *** on a big brake kit. My original intent was to run EBC Yellowstuff because they seem to get good reviews from truck guys. I couldnt find them in stock anywhere so I wound up with Hawk Super Duty pads. First impressions are very good, especially for only $200 for a whole set front and rear. Initial bite is WAY better than stock, under normal driving conditions they behave normally and are quiet with nice pedal feel, good enough that I think Ill be happy with just the pads and not have to spend $2000 on SSBC calipers. Though I really loved them on my RV, that thing stopped faster than most sports cars. I havent towed anything or had any super hard breaking events so time will tell but so far so good.
Next up I got a water tank from Trail'd. It mounts in the stock spare location, its 15 gallons and has two separate 3/4" threaded bungs for drain/fill. I picked up a couple ball valves that thread into place for easy drain/fill. Im going to be using this as a grey water tank. If you can read between the lines you know where this is going...
I had to modify the truck slightly to make it fit by cutting off some metal that is used to keep the stock spare in place. Essentially half of a steel wheel, seems completely unnecessary.
Bye bye
New tank in place. I do need to fab up some bump stops for the tank to snug up against. Its secure but has a slight wobble that I want to get rid of before its full of 15 gallons and Im bombing down dirt roads.
Next in line was airbags. Im going to be adding about 2500lbs to the back of the truck so I picked up these rad airbags from Full Travel Bags. (If you arent familiar, these are what CJC sells) They mount using a quick release for the air line and the bags so you can easily swap them out for the stock bump stops or aftermarket ones that mount to an additional sliding plate they provide. The bottom of the bag is completely free so you dont lose any flex and the bags have their own internal bump stops as well.
Here are some stock photos from CJC showing how the bags and bumps swap in and out. Its pretty slick, you dont even need to jack up the truck or take the wheel/tire off to swap them out.
The compressor I used is the WirelessOne system from Airlift. I mounted it underneath the driver side rock panel. Its up well above the lowest point of the truck so it wont get messed up offroad and there is still plenty of room for my Amp Powersteps to tuck up. Im contemplating making some kind of splash shield to try keeping away mud and road grime. They claim this is where its supposed to be mounted so we will see, hopefully it lasts.
I have a few more things to do like relocate the spare from the bed to the back of the truck. Ive already got something in the works for this, just waiting for it to show up. And lastly removing the Leer topper and Bedrug. Not sure if Im going to keep these or list them for sale. Probably sell them, so if anyone is interested in a nearly new Leer 100XR in silver for a Ram with 6'4" bed and a bed rug, make me an offer! All of this is being done because my new camper is almost ready. Immediately after selling our RV this fall I placed my order for a new Alaskan Camper which will be ready for pick up mid December.
My actual unit, Alaskan 650si. Nearly complete, just waiting on QC.
A
Atl-atl
Well a lot has been happening around here lately. It snowed in Flagstaff so I got in one good day of skiing and then we booked it down to the valley so I could start prepping the truck for phase 2.
Did some minor pinch weld and fender massaging in front and now my rubbing is totally gone, even at full flex.
Before
After
Threw on a Rig'd spare tire carrier so I could get the spare out of the bed. So far I like it. Definitely sticks out kinda far and reduces departure angle a little but not too bad. Also deleted the rear parking sensors and relocated the backup cam. Whats interesting is the rear cross traffic alert still works after deleting the sensors. Not sure how, maybe its camera based? Also chopped the exhaust tip to gain a bunch of ground clearance.
Installed Happijac camper tie downs. When the camper is off the truck the only thing you see are two small black tabs in between the bed and cab and then two small chrome tabs on the back bumper.
Then I got to removing the topper and bed rug. I bolted some 2x4s to my camper jacks and was able to easily remove the topper by myself in like 30 minutes. It even jacked high enough to clear the spare tire. Pretty pumped about that. Just need to rig up some ropes to hang it from the ceiling. Also removed the tailgate because the new camper hangs over just a little.
Docwagon1776
Midwest
It uses the sensors inside the brake lights, same as blind spot monitoring.
A
Atl-atl
Well here is the true start of phase 2. Brand new Alaskan 650si. A few mods still to do to the truck and after the first few nights in the camper the list is already pretty long. Loving it though. Its the perfect middle ground between the RV and a smaller/soft sided camper. Dont worry that hitch step isnt permanent.
Its so fancy. Its so much nicer than our old rental spec Thor RV. Its so much nicer than really any other pop-up camper on the market, regardless of price, and its priced in line with most of them depending on how you spec it. It genuinely feels like a mini Earthroamer. The use of space is perfect, the lights are LED but warm colored and everything is dimmable. The whole thing is power including raising and lowering the roof and nearly everything is monitored or controlled via bluetooth. 12v air con, 324ah of lithium, solar and dc-dc charging, toilet inside, shower outside(by choice) all the trim is real wood, no fake laminate BS here(other than the counter tops, obviously not real granite for weights sake.) And I can install/remove the thing in ~30 minutes.
olyelr
Kewadin MI
I just looked up alaskan campers. Wowzers, they look to be very good quality! I have never looked into slide in campers before, but i am familiar with travel trailers, and many of those are just cheap junk.
Docwagon1776
Midwest
I'd say it's neither cheap nor junk! That's an awesome set up for sure.
A
Atl-atl
Scored a like new Softtopper on Marketplace for $350!! Happy to have the bed covered and be able to keep things out of the elements when the camper is off.
A
Atl-atl
Been driving the truck a ton. Took the camper off a few weeks ago to do some work on it. Just finished fabbing a roof rack for it. I dislike the rack that Alaskan builds because its sticks up like 12" so I had them install just the brackets and then built my own rack that is super low profile. Its modular and bolts together, all .120 wall cold roll, mostly 1"x2". I made my own "molle" panels out of perforated sheet. Had it all powder coated and I think it turned out great. Plenty of room to mount my starlink, traction boards, and probably some other stuff that I dont even have yet ha! I contemplated making it out of aluminum but the weight penalty was only about 20lbs(total weight is about 50lbs) and the cost was substantially cheaper, like less than half. Got it done just in time to camp at a mountain bike race this weekend.
BHpgh
