B0095 DTC Help
Ghostexpress
Airbag light has been on for a little while now. Finally got a scanner that could read the codes and came up with B0095 Right Frontal Acceleration Sensor Internal Electronic Failure. Can anybody tell me if 56054085AA is the correct part number for a new sensor? And, can anybody verify that the location is inside the right door panel? This is on a 2014 Regular Cab 1500. Thanks for your help!
Fast69Mopar
Yes, the SRS Acceleration Sensor for the right side is in the right door. You appear to have the correct part number too.
