Back up camera issue
kenny davis
Arkansas
So I'm new to the form and I'm needing help, I just installed the OEM wiring and backup camera on my 2016 ram with the 8.4 screen, after several hours of following the instructions to a T iv have got a blank screen now, no radio no temp control, nothing. I haven't had anything flashed yet so I was wondering if this is normal? I'm starting to panic a little. I really could use some help with this matter ASAP.
Sent from my XT1585 using Tapatalk
jcarden10
Raleigh, NC
2014 Big Horn
Its been almost two years since I did mine, but I remember having the same issue. I think it was how I pinned the wires in the radio connector. I cant remember the exact pin numbers where the wires are supposed to go (31,32,33??), but I’m pretty sure the pic in the instructions had me thinking I was doing it right, but come to find out I had removed pins 1,2,3 which as one would expect are the power wires.
Again, this is all from memory, but I’m fairly certain this was the problem.
K
kenny davis
Arkansas
I was worried about that same thing so I checked it 4 time's ( late last night)and according to the directions I have them in the right spot. Still blank screen.
jcarden10
Raleigh, NC
2014 Big Horn
Post a pic of the connector. Also check out the thread about installing this kit. Its either in the DIY section or the Audio/Electronics section and pinned to the top.
K
kenny davis
Arkansas
I will thanks.
jcarden10
Raleigh, NC
2014 Big Horn
Below is a link to a post in the thread I referred to that shows how to correctly wire the radio connector. I know you said you checked it 4 times, but if your radio isnt getting any power at all, this is likely the problem.
Like you, I was certain I had pinned it correctly and had checked multiple times...and then I realized it was NOT wired correctly.
Installing OEM backup cam
https://r.tapatalk.com/shareLink?sh...orum.com/index.php?posts/978566/&share_type=t
K
kenny davis
Arkansas
Thanks guys it worked, I had some wires wrong, I really appreciate the info. Now I can stop worrying about it. Now on to the next project.
