Back Up Camera Issue
Deacon22
New York
The back up camera in my 2019 RAM seems to only work periodically. When it doesn't work, it's just a black screen. Then the next time I jump in the truck, it comes on. I've looked at some of the posts here and I guess this is still an issue. I have tried the turning the truck on and off, and open and close the tailgate. Sometimes that works, sometimes it don't. Is there a fix to this that I can do, or do I have to take it back? Called the dealer and he doesn't have an appointment for two weeks. Called another service dept at a different dealer and they seem to be insulted that I didn't buy the truck from his dealership. Told me to bring it back to where I bought it. =)
Any advice?
Aajakt
Hemi 5.8
I was having the same issue. Took it to dealer, they did an update. It has only been a week but no issues so far
[email protected]
Cape Coral FL
I've had this issue for awhile too. Slamming tailgate helps. Also have had recall U74,(tailgate latch), replaced. It(camera) works periodically now. I just wish they would replace these items when we tell them they aren't working. When I bring it in to dealer, it works fine.
grimlock49
2019 RAM 1500 Laramie
My Laramie camera with 12-inch screen just started going black today after 3800 miles. Will see what the dealer says.
millrat
NW Indiana
mine is doing the same thing now, 8.4 inch screen, going black fairly often now....
Elkman
Monterey
V6
With my truck the problem was the connector to the camera that had become damaged.
As to a service person at a dealer not wanting to work on a truck that they did not sell they are truly idiots. The guys who own the dealerships know that more than 50% of their income is from selling parts at a huge markup and providing service both under warranty and outside of the warranty. They would go out of business without this income stream.
millrat
NW Indiana
Dealer performed a software update today as well as the recall for the brake pedal. Time will tell if the update fixes the back up camera issue.
millrat
NW Indiana
well, that didnt take long, camera blacked out again tonight.....
OeRscriddles
Lock Haven PA
hemi
Seriously - the backup camera's are crap? Mine just quit working - black screen. I just bought this thing 4 weeks ago. Very upset. Please tell me the dealership fixed your camera. If I had known this was an issue I would have kept my Sierra. Never a problem with that truck - I just got to craving another Ram.
RamCares
n/a
n/a
Hi OeRscriddles,
We understand your frustration and would be happy to look into this further for you. Please send our team a private message if you would like some additional assistance regarding this!
Alex
Ram Social Care Specialist
twodips
2019 Classic
HEMI 5.7
The first thing y'all should do is take video with your phones. Show the shift knob in reverse and the screen black. Can't argue with video but they may try. I've had it go black, camera on while I'm going forward, sound going completely out etc.
Updates only work on DS trucks not DT's, found that out yesterday after hours at the dealership. Sometimes I wonder about what kind of idiots work for Star.
*****One item of note,***** dealers can no longer just order new radios, they have to get permission from Star/FCA first and it seems that's like pulling teeth.
512RAM
Austin, TX.
I jiggle the cable between the tailgate and bed. Has always worked for me.
millrat
NW Indiana
my dealer replaced the camera today, they had 2 in stock so that should tell you something right there... time will tell if its fixed.
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
Any advice?
had a problem like that also on my older 2013 Big horn they changed the wire harness that's from the bed of the truck to the tailgate worked fine for about 3 weeks then the same thing black screen on the radio when the rear view camera came on end result was the 8.4 nav radio had to be changed crazy its like they play a guessing game till they hit the right part that's bad
Randy Taverner
London Ontario
madtrucker2016, I encountered an issue where I lost the use of my back-up camera this week on my 2016 Ram. Something similar has happened on about half a dozen occasions over the past 3 years that I have owned the truck. After checking YouTube for similar problems with the Ram back-up cameras I took several steps in attempting to correct the problem. I did a Factory reset which did not resolve the issue. The camera picture was washed out. I took the further step of downloading an update that was available on-line and went through the steps recommended on YouTube to install the update from UConnect through a flash drive with the 2 files I downloaded from UConnect. UConnect also provides written instructions on downloading and installing the update, which worked after several attempts. At first, I did not extract the files, as instructed. If you do not extract the files, the UConnect system will not read the file from the flash drive. Anyway, that did not resolve the issue. Instead of the washed out picture I now got a green screen with nothing, and intermittently, a washed out picture again. So following another YouTube video, I took out the 8 torx bolts that hold the flat panel on the inside of the tailgate that covers the lock mechanism and camera. I could see nothing obvious with the wiring or connections. But I unplugged the larger wiring harness and after a quick look at the pins and socket I clipped the harness back together, ensuring that it was tight. A very simple procedure, really. I then started the truck and put it in reverse and the camera, for the first time in about a week, was working perfectly with a clear, clean picture behind. Just what that simple act of unclipping and connecting back the harness did, I am not sure. It is possible that a small amount of moisture had collected inside the harness, enough to cause a short in the system, I'm guessing. Unclipping it and connecting it back together may have been enough to disturb the moisture and cause the connection to start making proper contact again. As a last step before putting the cover back on, I used a good rust inhibitor/lubricant/water displacing penetrant to spray all the lock mechanism and any bolts I could see to prevent rusting and to lubricate the moving parts. I made it a point, since the product I used is a safe di-electric product, to spray all the wiring harness connections to prevent moisture from getting in and causing future shorts. The product will not conduct below about 40,000 volts but will not interfere with low-voltage current either. I hope this simple procedure resolves my problem once and for all. I noticed that many others have experienced the same issue with their back-up cameras on the Dodge Ram over a period of years. Before going to all the more complicated procedures mentioned earlier, try that simple fix. It may just work for you as well and hopefully save costly repairs or unwanted downtime.
millrat
NW Indiana
12 days and still working perfectly...it would have acted up by now with the old camera but still leery of saying its fixed yet...
Steelerfan53
Niagara Falls, Canada
Hi Ram Owners,
I traded in my 2015 GMC Sierra 2 weeks ago for a 2019 Ram 1500 Sport, this truck is all blacked out and really looks aggressive. Yesterday afternoon my backup screen (8.4 u connect with nav)quit, it was completely black and did not work for the rest of the day. This truck has only 400 kms x(248 miles). Today, the camera is now working again????. I have owned only GM trucks and never had an issue, l love this new Ram but now l am having second thoughts.
