Battery Blanket ?
Ken226
Washington State
back in 2009, the Dodge Ram HEMI, had a real nice Battery cover/blanket
it is so much better than the 1950s type oil filter looking thing
That cover was used up until at least 2013. Mine 2013 6 speed has it.
One of my coworkers has a 2014 8 speed, and has the cover that looks like pressed fiber insulation.
bugslife
florida
I was told that down here in South Florida it would be better without a blanket. Is that wrong?
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I started using Peppermint oil spray to help keep critters away !
Will see how that works
THANK YOU all for your replies
Dusty
Rochester, New York
On 5th gen gassers, will an H8 fit directly onto the battery tray without modification?
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 132150 miles.
RamDiver
Marlborough, Ontario Canada
2021 DS
Yes, from what I have read, the 5th gen has a similar battery tray to the 4th gen.
Remove the plastic block, and an H8 battery drops in.
You will require a new battery insulator cover.
Check with Benny @AllMoparParts.com for a replacement cover 5033397AE.
Dusty
Rochester, New York
Thank you!
Regards,
Dusty
in the Battery Tray, there will likely be a
BATTERY Monitor
Although some trays can be made to hold a larger battery,
You may need to move the battery monitor to a nearby location
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
BATTERY Monitor
I am going to stay with the H7 800 CCA
RamDiver
2021 DS
Just curious as to what you mean with the aluminum, I'm always ready to learn ???
Crash68 was quoting Stenerson's post about wrapping his battery blanket with an aluminum heat shield protector. :cool:
I bought the mopar cover for my new h8 sized battery. I wrapped aluminum heat shield protector around it.
