bbk install last night
badfish888
Va beach
2012 hemi express
.....FAIL, What a pain, every thing wen on smooth except for 2 broken header bolts, and the bolt on the driverside, all the way back above the starter, HOW the HELL did any one get that in, i cant even touch it let alone tighten a bolt. ANy tips for that. i got every thing else on including the rest of the bolts, i tightened the rest of the bolts down in the torque pattern to 28 ftlbs, and i couldnt see or feel any leaks, but its hard with tthe air for the fan. id realy like to get that bolt in there, but after 6 strait hours, 2 broken bolts and a headache later, i gave up last night............................HELP
Trupiano
Registered User
6.7L CTD
Have you taken out the front wheel well liner? Shouldn't be a problem with it removed. Maybe remove the front wheel too? I remember I lifted the front en of my truck up and removed the front wheels and I could reach everything. Good luck man!
badfish888
badfish888
Va beach
2012 hemi express
i had the liner and the wheels off, but on the bbks the back pipe has a upward loop that comes almost a inch away from the back lower bolt, and goin up from underneath the starter is in the way, and the top is even closer. Im at a loss here, i cant take it off cause the gasket is already crush sealed
Trupiano
Registered User
6.7L CTD
Hmmm that sounds kinda tough. Are you just trying a rachet and socket? Have you tried a universal joint, or an open-ended wrench?
Post up a pic so we can see what your looking at, maybe we'll have a better idea if we can see for ourselves.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
yep, post a photo
badfish888
badfish888
Va beach
2012 hemi express
k standby, BTW if i have to take it off, will i b able to re use my mopar gasket, or no cause it has the crush ridges on the block side?
badfish888
badfish888
Va beach
2012 hemi express
the one directly opposite side of the far right one
Redtruck-VA
Virginia
I'm guessing here, but can you reach the bolt from underneath? Maybe slot the header flange bolt hole. Looks like the header will need to be unbolted and the bolt inserted in the flange and then threaded into the hole a head of the other bolts. Maybe you will need a shorter bolt for that hole. Just throwing ideas at you. Good luck.
badfish888
badfish888
Va beach
2012 hemi express
would i be able to take it off will the gasket still be useable
badfish888
badfish888
Va beach
2012 hemi express
?????? how bout removing the starter, any one done that on a 3rd gen yet
badfish888
badfish888
Va beach
2012 hemi express
IN THE PIC, far right tube bottm bolt, the one you cant see, i cant even get my hand close enough to touch the hole
glass3222
Central PA
I had to go in from the bottom. I cannot remember exactly how, but it you move around you will get to a place you can reach up in and lean you head a certain way to see the hole.
badfish888
badfish888
Va beach
2012 hemi express
I GOT IT!!!!!!!!!!!!!!!!!!!!!!! starter out gave me just enough room,
ahhhhhhhh, relief at last, no leaks. how long should i go before i should retorque em, and do i need to keep doin that. Thanks for all the help guys
Ares
Az
2003 / 2012 / 2004
4.7L / 5.7 / 8.3L
Exhaust clip?????
Standing by....
and yes, if you had to take your headers back off you can reuse the gaskets.
glass3222
Central PA
I would retorque in a couple hundred miles. Then check every 5k or so
badfish888
badfish888
Va beach
2012 hemi express
im not sure how to post videos, but it doesnt sount to much louder then stock at idle, cant wait to wail on it/
GoMangoMan
Radiator Springs, Pa.
Dang, makes me wanna run out and start my install ... NOT! (I suppose I need to decide which header to purchase as I still have Edelbrock questions in another thread) Glad you got it worked out. It's nice that everyone comes to your aid which is the great thing about this site.
