belt squeel
RamWagon
After the past year or so ive switched from running just 87 oct to 89
And ive noticed that when i hammer on it that the belt will squeel when it shifts 1-2 and 2-3. Anyone else have this issue? My set up this past year has just been exhaust. CAI and a canned tune off of the diablo. About a month or so ago i had finally contaced hemifever and got the 87/89, 91 and 94 tune when i had finally made the switch to full time 89. Is this as simple as a bit of adjustment on the belt? A new belt? Or contact sean to get some tweaks
bassheadhemi
Montreal, Canada
Bigger pulley on your alternator might help, but will probably lower the alt output at lower RPM.
JasonK94Z
Anderson, SC
When I had my Z28, it had belt squeal after I installed a shift kit. The hard shift caused it. I replaced the belt with a Goodyear Gaterback belt as advised on the camaro boards and all was quiet again.
CapeRR
Nova Scotia
I put a Gatorback on mine because is started to squeal on damp mornings and it hasn't made a sound since.
