Should i just replace the control arms
  • Yes
    Votes: 8 100.0%
  • No
    Votes: 0 0.0%
  • Total voters
    8
pjschu55
Illinois
4.7 Magnum
Guys, need some advice/help. So i raised the front end on my 04 Ram 1500 4X4 with a 2 inch level kit (torsion keys) and the rear with 2 inch blocks on the leaf springs and it looks great. Ever since then ive been blowing out cv boots (minor tears really). When i got the truck i slid off the road and into a ditch and after that ive had nothin happen to the truck. Me and my mechanic that i take my cars too first thought it was just the cv angle. The drivers side has had no issues at all but the passenger side keeps doing it. We recently discovered that the lower control arm is bent on the passenger side and a slight bend in the upper shock mount as well after looking more closely at all the suspension and i wanted to know if that could be a possible culprit for the boot tears. I may decide to just do a new lower and upper control arm and new ball joints in case other components may be compromised.
McBroom
Denison Tx
Hemi 6.4L
That’s the most likely culprit.
Are the front tires wearing evenly? Especially the right tire.
If it has any odd wear on it then yes replace both upper and lower A arms.
Depending on how many miles are on the truck I recommend changing both sides and also be sure to get the arms with serviceable ball joints.
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
pjschu55
pjschu55
Illinois
4.7 Magnum
The passenger tire camber is definitely off 100 percent and it is tilted in for a slightly negative camber. I have pic but its not the best haha
pjschu55
pjschu55
Illinois
4.7 Magnum
And i want a Rebel so bad!!! Or just finaly get a Cummins hah
McBroom
Denison Tx
Hemi 6.4L
Get the ‘19 Rebel 12
Too many maintenance requirements on the CTD
- The Blue Mule
noraa73
