BEST HEAVEY DUTY BATTERIES, 3500, 6.7 D, DUALLY
tmcgraw
California
Cummins 6.7
I HAVE TO REPLACE MY BATTERIES ON A 2018, 3500, 6.7 DIESEL DUALLY LONGBED. I WOULD APPRECIATE ANY RECOMMENDATIONS.
Jkidd
Central Arkansas
5.9L V8 magnum
I would go with a set of Interstate batteries. I have them in all my vehicles and have little to no trouble out of them until they are dead dead. And when I say dead dead I mean when they are bad they just stop working and it is time to get a new set.
Dean2
Near Edmonton
Go buy the right size at Costco. Their batteries score very high in all the tests and you just can't beat the warranty on them. Every replacement battery I now have is from there. Unlike many, I don't just return them every couple of years for a new one becasue I think that is abusing the system. I have some that are going on 10 years in service and still test perfectly fine. (I do keep them charged if they sit over winter.)
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
My suggestion is get the larger H8 battery vs the H7. I think the H8 is in the eco diesel.
I typically try to buy name brand batteries but others are just as good.
I keep my batteries on a trickle charger if out of service more than 3 weeks.
I wish there was 1 major brand that was better than any other. If there is I have not found it.
CanuckRam1313
Ontario Canada
2023 Warlock
Interstate H8 AGM battery! Worth the bit extra to get into an AGM battery over stock lead acid types.
I just replaced mine in my 19'. With the help of this Forum and it's excellent knowledgebase I upgraded my stock H7 to an H8, and went with an Interstate AGM.
Remove the battery and on the battery tray there is a little tab you can use a flathead screwdriver on to pop the tab out. Then the try fits the H8 size.
It was an immediate improvement in cold starting (stock lead acid H7 is about 730CCA / Interstate H8 AGM is 900CCA), and also a big help with my electrical system as I have an aftermarket audio system in my truck.
One of the largest capacity H8 AGM batteries is the Odyssey 49-950. Highly rated battery and it's made in Missouri. I have one in my EcoDiesel (only use one unlike the CTD)
CanuckRam1313
Ontario Canada
2023 Warlock
Now that's a battery; 950CCA is no joke!
And here I was thinking my H8 Interstate AGM at 900CCA was a beast.
The full specs of the 49-950:
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Few months ago, 2 WallyWorld EverStart Platinum AGM 850CCA. and best price around at $170ea. Gone though the 3 night run of -32°. With the trickle on them overnight started without a hitch, the fuel and DEF was a different story. 4 yr replacement warranty
2019RamInSC
Army
South Carolina
Just bought the same battery. Right at $200 after taxes and core. Interesting, made in Germany.
DILLIGAF
Canadian Forces
Canada
Odyssey is the only battery that can keep up with me winching all the time.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
PREMIUM​
MTX-49/H8​
$289.95SRP
Group Size H8
900 Cold Cranking Amps (CCA)
1000 Cranking Amps ( CA )
160 minutes Reserve Capacity ( RC )
95 Amp Hours ( AH )
Interstate’s MTX absorbed glass-mat (AGM) battery
Advance Auto Parts recently bought out SEARS DieHard Batteries
They are having a big promo on them, but it may be online only
One of their new batteries is an H9, it may not fit our Rams
DieHard Platinum AGM Battery:
H9 Group Size,
950 CCA,
1000 CA,
100 Amp Hour Capacity,
Height: 7.5 in
Length: 15.562 in
Width: 6.937 in
