Best Mods for Under $100
U&A
2016 3500 SRW
6.4 HEMI
No.
They just prevent your engine from absorbing dirty oil pushed through the PCV valve. It's a preventative measure.
just a small change :)
U&A
2016 3500 SRW
6.4 HEMI
never knew people vinyl warped interior trim in a truck.
SirMarco
5.7L HEMI
Installed my tail gate assist yesterday. Worth the money..
R.L.K.
Bristol , Tn.
I just purchased the Dee Zee tailgate assist. I used one a week ago on a buddies truck , can't believe I haven't done this already . Purchased front car id .
Atincup
Frederick MD
What did you do with steering wheel controls? Add them?
Yes. They work like a charm and was a fairly easy mod, except for that darn air bag. There is a great write up in the DIY section.
joeygster
Ancaster, Ontario
Regarding the rear seat back mod.
I researched this mod a lot before deciding which approach. I decided to cut the rear seat back hooks rather than washers to raise the seats. Cutting the hooks is easy, doesn't change the seat height, is free and performs perfectly.
Great variation John.......I really like that idea.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I researched this mod a lot before deciding which approach. I decided to cut the rear seat back hooks rather than washers to raise the seats. Cutting the hooks is easy, doesn't change the seat height, is free and performs perfectlY
I was waiting for someone to do this with the new hook style. I'm thinking I'll do the same but bevel the nylon edge like the factory setup so it slides on easy.
Thanks for posting this! Adding spacers is not working for me. Almost an inch of spacers and it still won't come off easy...
TonyMM
2016 RAM 1500 CC 6"4 4X4
It should not come that easy especially if you wish to retain the security for the passengers in the back seats.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Easy for putting it back in place...is should rest in the sane position it always has when hooked.
Treburkulosis
Glorified Car Washer
Haslet, TX
Next month I am doing the tail gate assist mod. I've spent enough this month between wheels, paint, and tint.
Treburkulosis
Haslet, TX
I almost did it last night, but I sweet talked the wife into tint, so the assist will have to wait. I really like not having to hold the tailgate when I open it.
