Going to try the Icons I think - but can only find 24" in the A version, no B version, unlike the 22"r's which come A and B. Does it make that much if a difference? Seems most other brands spec the same wiper for Driver and Passenger side.
I'm going to try refills on my OEM blades (which look like Icons). I like the look of them, and hate to spend $40 when I can spend $10 for refills. My experience with the Icons was that they chattered quite a bit and didn't always curve enough to make contact with the windshield all the way to the end of the blade. I even cleaned them and clay-barred my windshield to no avail. I don't mind spending money on something that is noticeably better, but they were not worth the extra expense for me.
2nd vote for rain-x /Getting 24's next time.
I lift the wipers away from the windshield before the snow falls..old new england trick ,
I don't know off hand but there are actually 3 different "levels" of Mopar blades apparently. I believe it goes like this, value line, Magneti Marelli, and then OEM. So you have to be careful if you are buying them online and don't physically see which blade you are getting.
Have you taken the wiper arms off? See the side ways T above the end of wiper blade. That is were wiper is supposed to stop/rest. Yours is 2" low. Unless there is some reason that I'm not aware off. You should raise your wiper arm, then it won't hit the molding.
Curious about the 24 inch claim
Bosh Icons are boss
I used to think so for the most part about those but the last set of Icons I had didn’t even last six months before they started streaking like a cheap set of dollar store blades.
I’m about 5 months in on my Trico Force blades and they’re still wiping like they’re brand new.
