6,000 miles with PP 5W-20 with Wix XP filter. Analysis came back even better this time with a slightly longer OCI. I think I will start doing 7,500 from now on.
Pretty perfect for a hemi, what oil did you use last time? 7500 good idea for sure, maybe more.
Wow, your engine really likes it!
How does it sound? I didnt try PP, but PYB and PUP in mine sounded OK for a little while....around 2500 miles or so on each OCI it started to sound noisy again.
Same oil, different filter (Bosch Distance Plus). I did much more short trips on this most recent change.
What does high "ear" engine mean?
So some of the no tick/very little tick guys could maybe get away with PUP 5W30/5W40 and a Mopar filter changed at 4-5K intervals if they were really worried about voiding there warranties.......... having a receipt that said 5W20 for their records of course. Personally I'm not convinced that any oil with less than 150-200ppm of Moly is going to cut it for the long haul and even that amount of Moly is still not going to make me want to go longer than 4-5K between changes.Interesting, PP went to sn+ basically means low calcium, and it looks like the last change was old stock PP but the previous change was sn+, just an interesting note imo. While those numbers are near perfect for the hemi, better then like 90% of them, there still is room to improve because hemi's are high ear engines. It might be possible that 5w30 PP will even drop those wear numbers more. PP 5w30 is a very thin 5w30, there would be no way to even tell it was a 5w30 in a uoa. The viscosity starts at 9.8, pdf. But will be in the 20 weight range during your interval. I use PUP 5w30 in my wife's rav 4, it is very much smoother then 5w20, but as you can see on stat sheet nobody could tell the difference. Up to 9.3 operating viscosity is a twenty weight, up to 12.5 is a 30 weight, so as you can see PP 5w30 is more close to a twenty weight then the upper limit of thirty weight. Just something to consider, it is a little more protection but at near zero risk as it is so close to a 20 weight and carries fca spec ms6395.
I put the same oil in again this time, 5-20 PP. I'll let it run the course this time and then make the switch to 5-30 PP or PUP. Look out for another post in 6 months or so!
I had a bunch of 5-20 that I bought so I had to get through my stock first before considering switching. I'm just happy to see nothing crazy from using 5-20
That is a fantastic report for 13k on the OD. Iron at 30ppm? Very NiceJoined the cool kids club with an oil analysis. Hopefully you can zoom in to read it.
Good looking report! I would stay around the 5 to 7 range for your interval. What filter did you use? Also what oil went back in?
