Brakes?
RamHemi2500
North jersey
2015 ram 1500
What's a good brand to get. I'm interested in Brembo or Wilwood for my 2015 Express Crew Cab Ram 1500. I like the get caliper look. But have no clue on where to start i.e. Caliper size. Rotor size. Ect if someone could help me out.
charonblk07
Calgary, Ab
F1-A forged 349ci
Your big brake options for the Ram are the SSBC tri-power 3-piston kit with a 14" front rotor for $1400, the Baer S6 6-piston with 15" rotor for $3900, or the Rotora (if available) 8-piston with 16" rotors for $7000. I had the SSBC kit a while back and they were better than stock for braking and use a standard Ford pad so they can be picked up anywhere, the Baer uses a harder to find D1247 race-only pad, and the Rotora pads can only be had from Rotora. Keep in mind, these are all for front calipers/rotors only, nobody makes a rear big brake kit for the trucks.
