Camshaft Position Sensor Question
RAMMAR
DIRTY DIESEL DRINKER
Victoria, BC
Hemi V8
Where is the camshaft position sensor located on a 2010 Ram 1500?
Sorry if there is already a thread concerning this....
WilliamS
Tampa FL
passenger side of the front of the motor. Look behind the belt tensioner pulley from the top you will see a connector and a part that has 1 bolt holding it down. Thats the sensor. Once you pull the air box off its likely the easiest sensor on the motor to replace.
Edit??!! Did some homework for you
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Also, it’s not best practice to label a thread title “question”. It doesn’t help future members find the solution to a similar problem.
RAMMAR
RAMMAR
Victoria, BC
Hemi V8
Okay.
Thanks a lot....
