Can someone post photos of 1500 Sport Reg Cab 4x4 suspension
MarineRam
Camp Pendleton, CA
I have a '13 R/T non-4x4
I am looking for photos of front suspension- upper shock mount, springs, and front lower control arms.
Other than 4x4 half shafts, is everything else the same as non-4x4?
Thanks
charonblk07
Calgary, Ab
F1-A forged 349ci
Frame mount, spindles, lower control arms, sway bar, shocks, and springs are different between 2wd and 4wd. 2wd spindles are 1" shorter on the top arm but that's the only difference and either can be used depending on what you are looking to do.
2wd suspension
4wd suspension
M
MarineRam
Camp Pendleton, CA
I'd like to do coilovers up front. My thought was to swap the front lower control arm to 4wd style. The front coilover shocks mount the same as 4wd. I am told they are not available for 2wd control arms.
charonblk07
Calgary, Ab
F1-A forged 349ci
The upper shock mounts are different as well so no coilover for a 4wd will work on a 2wd even with a swapped lower control arm. You would have to cut out the shock mount and weld in the 4wd mount but if you're doing that then you may as well weld in aftermarket mounts and do the job properly.
TMFMK
