Catch can for dummies..
bamablack11
So.. Uh.. What and why is the catch can? Anybody care to explain...
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Catch can collects the oil that is being pumped through your PCV valve. Without a catch can, oil is routed through the PCV and dumped into your intake manifold. This oil builds on inside your intake and gunks up your throttle body as well. On top of this, it mixes with your fuel, and lowers the octane rating of the fuel. The catch can simply collects this oil and prevents it from making its way into the intake manifold.
If you look at the link posted above, you will also see a youtube video showing the installation process.
B
bamablack11
That would explain why they recommend a tune up every 30k
RLJ10X
Southern Indiana
I have the one from Moe's. It is a machined sculpture. It's too pretty to be hidden under the hood.
I dumped mine out the other day. I'm glad all that octane robbing garbage didn't go thru my engine. If you can't tell, I like mine a lot!
B
bamablack11
I will end up getting on for sure.. Be like a month or so though
B
bamablack11
Welp.. This may or may not be one of the first things I do..
