CEL after header install ??? With Hemifever tune!!! Please help
BEAST19
IMG_1468.JPG67cf29baeb4b0ba8f6e1632e368f334e.jpgIMG_1470.JPGd0f8d0b420204db14ec1faf8d065c486.jpg these are the codes it's throwing ..... After I did two 0-80 runs.. abyone else experience this or can tell him if a tune would fix it?? I checked all o2 wiring and all looks good.... I'm guesssing a tune will adjust and Fix ... Just computer registering the new air and temps coming thru pipes ...
MADDOG
Living in a Firepit
Clear the codes and run it again.
RusslRam
^^after that do feel or hear anything different/wrong when/if the CEL comes back on
Sent from my Pixel using Tapatalk
BEAST19
BEAST19
Cleared codes .... Restarted truck. Light came right back on. Start up was different.. didn't rev as high upon initial start then idled normal but I didn't let it run long or drive it after .
RusslRam
Was the hemifever tune done before the headers?
BEAST19
BEAST19
Yes but he swnt me one prior to headers being installed he stated were for the pedal comannder and the headers that I coiod upload and run before headers were installed and thats whst I did . I'm hoping it's something to do with that and a quick fix
MADDOG
Living in a Firepit
It could be but if the codes came back after clearing them I suspect it may not be the tune but some other fault. Is the O2 sensor new?
BEAST19
BEAST19
The 02 sensors are stock I believe.
BEAST19
BEAST19
I'm just thinking if the tune wasn't correct from the get go that when I really cranked on it it set off the sensors tripping the light .... Guess I'll wait for sean to get back to me from Hemifever. And I'll call moes performance as well in the morning.... This stuff always happens on the weekend :-(
BEAST19
BEAST19
I also switched my pedal commander to sport 3 before I hammered on it ... Not sure if that has anything to do with it
Txhemirt
Lubbock, Tx
Did u plug in the 02 sensors with extensions or strap the 02 wires
BEAST19
BEAST19
I had a shop do it . He used some zip ties I saw and maybe extrnsions I'm not exactly sure ....Seeing I didn't do it I'm not exactly sure . I could only see two sensors ... Do u know if there are more . The ones I can see the sensors and harness look intact and plugged in
Johnnymac2k6
Ohio
2007 Ram 1500
Long tubes? Shorties? Cat deletes? You haven't given nearly enough info to diagnose this via keyboard. Did they delete the cats? Relocate them? Does the tune have the post cat warning lights tuned out?
Sounds like your first 2 phone calls monday morning need to be hemi fever and your exhaust shop, as one of them either goofed the tune, or wasn't smart enough to correctly plug in the sensors, or tell you that trouble codes are going to happen with a cat delete, unless custom tuned CORRECTLY.
There is a pre cat, and post cat on BOTH sides originally. With long tubes you usually have the rear one programmed out with the tune, and cats are deleted. UNLESS you put in high flow cats or had yours relocated. Of course none of which was specified, and all of which should have been conveyed to you by HF and your shop.
BEAST19
BEAST19
Ok so this is the info know. I ordered arh long tube headers with cat. The headers were installed at a shop . Prior to them being installed Sean at hemifever wrote me a tune accommodating for my headers .... (I spoke with him via email about the codes and he says they are definitely o2 sensors related) I also sent him a log .
I went under the truck a few minutes ago and looked at the o2 sensors and harnesses and didn't see any signs of melting or pinching ..... I did notice the harnesses/extensions that are used all have the same plugs which may have made it easy for a simple mistake of plugging into the wrong plug??? Not sure if that cause these specific codes .
It was my understanding the high flow cats would allow for both sensors to be in use without a delete .
I'm hoping it's a quick "switch plug fix"
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Sounds like the sensors are plugged in at the wrong location. They need to go back in exactly where they came out, and I'm willing to bet he shop just got them mixed up when they put it back together. A circuit code is 9/10 related to a wiring issue.
BEAST19
BEAST19
Copy that thanks headed to the shop in a little bit!
BEAST19
BEAST19
UPDATE:
May have figured it out! Checked the o2 sensors numbers and locations with the ones from dealership , one was out of place along with one of them being a wrong number??? (Keep in mind they were my stock o2 sensors) anyways cleared codes and moved sensors , and ensured all wiring and connectors were good... So far no code.... Drove probably 20 hard miles so far.
So learn from my installers mistakes.... Don't mix up the o2 sensors when swappjng from stock to longtubes. !!! Fingers crossed it was a simple fix
Sillygoose
NY
make sure your tune does not have the rear o2's turned off, otherwise you'll have issues with your NY inspection
Glowz
