Check engine light on (again)
drooler
Alberta, Canada
2015 Sport
Midway through a roadtrip my check engine light came on. This happened once before requiring a "reset" by the dealer (no explanation given).
After reaching our destination the truck sat for 2 nights. The following day I started it and the light popped on. Also, the remote start will only work for about 5 or so seconds before shutting off. I'm also getting an occasional "key fob has left the vehicle" message.
Any thoughts?
Ratket
Arizona-
When my
Truck through the "Evan code" like loose gas cap-
I couldn't use my remote start. That may be why u can't use remote start.
MdMassey
Take it to your local O'reilly's and have them scan it.
P0442 and p0456 are the "gas cap" codes. Any other code could be a developing problem.
huntergreen
Marine Corps Navy Badge
Buy one of what?
ColdCase
Buy one of these for 20 bucks and take the power away from the dealer!
Dang handy to have too...
If you are going to spend money on one of these, get one that can read/reset ABS and Airbag codes too. These entry model ODB readers won't do that. You'll thank me later.
ColdCase
Oh, remote start is typically disabled if there is any check engine codes set, doors/hood open, low fuel. Sometimes it will start and run for a few seconds.
Get the code read, the dealer may have just reset the fault code.
WilliamS
Tampa FL
you can buy a obd2 scanner for about 20 bucks, 10 if you get one on ebay. it will tell you the code and you can decide if its easy enough for you to fix.
Also with a check engine light the vehicle should not start. Its programmed that way.
