Check engine light when turning
Jacob K
Brunswick, GA
2014 Ram 1500. Occasionally when I turn right, the engine hesitates a little and then the check engine light comes on. After a few days it goes off. Every time I try to take it to the dealer to get the code read, it goes off before I get there. I’ve heard of the gas cap issues and went ahead and replaced it and check tightness every day before I get in. Anyone have anything similar or know what the issue could be? It’s obnoxious.
Brandon-w
Yukon
2015 Ram 1500
I legit just ran into a guy at the gas station that says he's having the exact same problem. He too didn't have a solution. He said it dings, a lightening bolt pops up on the dash and then bam its gone.
Weird thought and not trying to lead you down any wrong trails but being electric steering I wonder if sterring angle sensor issues would cause havoc like this?
First thing id do is go get your battery load tested. Voltages do weird things.
J
Jacob K
Brunswick, GA
Thanks. Yeah someone told me the same thing. Just got the battery replaced before a road trip with the family a few months ago. The other odd thing is if I coast through the turn, it’s fine. But if I power or accelerate through the turn, it starts hesitating and bam...check engine light.
Try running a separate ground from the engine to the battery for fun.Any bolt on the engine will be okay to bolt to.The engines in the trucks can move around a lot,especially if you're accelerating on a tight turn,they use a visciuos motor mount,if the issue still persists that would rule out a bad ground being strained under load,and you can start looking elsewhere.Make a ground up out of at least 10G or more for testing purposes
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
Had that problem on a Bighorn I don't have any more but it happened the day I picked up my truck brand new from the dealer same exact problem. Went back and they had to replace a sensor something to do with the gas system. good luck
mtnrider
Georgia
You need to know what the code is before you blindly start throwing money at it.
Next time it comes on just go to a local auto parts dealer (autozone, pep boys, etc) and they will read the code for you at no charge. At least you will have an idea of what it is and a starting point.
audiophile
5.7L
Not sure if this is your answer but my dad's '94 Dakota did a similar thing and the culprit ended up being the fuel pump.
Red Ramdd
Dansville, New York
5.7 Hemi both
red lighting bolt means there is a lost connection to the ECM usually a connector pin losing contact.
Tach_tech
5.7L HEMI
That’s not correct. The lightning bolt light is to indicate a issue with the ETC ( Electronic Throttle Control).
Beaconmember1
Tampa, Florida
I have the same issue with my 2008 Dodge Ram 1500 Hemi. I had the ETC replaced, the sensor replaced, and new wiring from my ECM. Not only does my truck stall at turns if going to fast, it also stalls sometimes when I back up and stalls when I hit bumps in the road. I have taken my truck to 3 mechanics but my truck problems continue. I'm told from my mechanic that it's a wire shorting out somewhere or a bad ECM. I'm leaning towards a bad wire short somewhere. I would think my mechanic would have checked the connector pins to the ECM, but I'll reach out again to my mechanic to make sure he did that.
mtofell
X2 - or just buy one on ebay. I got mine for less than $50 and it's a great tool to carry with these modern vehicles. Not only can you instantly pull a code, you can also erase/reset them to see if it was just a fluke.
Daw14
South Florida
Do a throttle reset turn key to run let the dings finish slowly depress gas pedal to floor then slowly release fully.then start truck.
