Clearance on Sport trim level
hunterdan
SE PA
2019 classic
For further information, here's this link
hunterdan
SE PA
2019 classic
Factory part numbers ,find them.Otherwise it's nothing more then a rumour or whatever you think you know.
It's not a rumor. It's fact. You're making it clear you don't know what you're talking about. How can a truck with the small tires have raised ride height as an option then?
I'll say it once again,post up the factory part numbers for these so called springs you're talking about.I'm guessing you already looked and couldn't find anything to back you up,so now you're scratching bottom for excuses,lol.Once you find a factory part number showing their's differant springs,i'll believe you till,till then not so much. I already went through this at the dealer several years ago,when i was lowering my raised ride height 4X4,i started out looking for factory springs that were lower or differant at the dealer,and only the R/T has a differant spring
hunterdan
SE PA
2019 classic
Coils are the same, struts are different. 2016 outdoorsman (raised ride height) uses
68040882AE for a strut.​
2019 classic similarly optioned, standard ride height, uses 68040880AH, confirmed through a dealer. And yes, it will list various trims for both struts because the raised ride height is available in nearly every trim, not just some. But it is standard on rebels, warlocks and outdoorsman trucks
dtomar
Washington
My 2016 Sport has the air suspension option which allows you to lower the truck height to get in/out and 2 settings to raise the truck height above the “normal” height. Does this truck you are looking at (very sharp by the way) have the air suspension option?
Light299
AZ
5.7 gas
Yea, it's funny wild one thinks only the spring P/N matters... the spring land on the strut matters just as much...
Grizzly Clay
Electric City Wa
6.7 cummins
I have a question about my Wife's 2013 Ram 1500 Sport.The dealer we bought it from last year detailed it and waxed the stripes.There is now a haze that won't come off of the stripes.Any suggestions on how to remove the haze?
Hemimania
Central NJ
I am looking to buy a Ram 1500 around 2015-2018. I am in discussions with a seller. It is the sport trim with the black strips and 20" wheels. The contouring at the bottom looks to be lower than other trim levels - I could be totally wrong. I go offroad and pull trailers a lot so I would prefer a trim level that is not lower. Is this just perception or is there some contouring on this trim that brings it lower to the ground? Thx
I don't think they are any lower than any other Ram. Good looking truck, though.
C
cbird02
Tucson, AZ
2020 Ram 1500 Classic
The same springs do not come in to play here. The trucks frame can sit the same, but the body panel/bumper effects that give the sport look can drop lower down than the normal panels/bumper. My concern is f-ing up those body effects while off roading. Clearance to the underside should be equal or even better on the Sport due to the extra inch provided by the larger 20" wheels.
Ain't no spring land on the rear diff now is there.But you're funny too,thinking there's only one end to the trucks,lol
C
cbird02
Tucson, AZ
Man, the Ford forum I am used to is way less brutal than this forum! Is this telling us something about Dodge owners?:D
Marshall
Sk, Canada
2014 sport
My 14 sport don't look ant different than the other trucks around here, and there are lots of them.
There is a few Ford guys , but I out grew that silly's 40 yrs ago
Mine is standard 20 in tires, 4x4, a 2wd may be lower? I had one 2005 and front was lower than this one. both club cabs.. This is when new, I do have build sheet, but not going to dig it out and get in the fight. BYW , no air ride, I hear that is problematic at -30 or 40 as we have quite regular here. Would be nice thou as the wife is starting have problems getting in the truck. I do have boards on it now. 2014 ram.jpg
BHpgh
