Cold Air Intake
Scott Sanders
Winston-Salem
2019 Ram Classic/ Maxtrac 4.5/3" lift/ Nitto Ridge Grappler 35x12.50x20/ Fox 2.0 shocks/
Moto Metal 20x10/ Magnaflow catback/ Heise LED lows and fogs/ Simple Kicker audio system/ Nitro Diff cover/Tyger Trifold/MGP Caliper Covers/Tinted Tails/ Rolling Big Power Stealthboards/Black Quad headlights/Hellwig 7883 Swaybar
Does your wife know about all this? :)
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Oh yea....that's nothing, I had the car below for 8 months and sold it, lost some money, but had to get back in a truck!
Tray Burge
On the porch
Vararam only way to go.
Had a K&N hot air sucker and threw it in the trash.
Install the supplied decals included and it's good for an additional 30hp.
Hemi395
Cape Cod MA
I am using my third Volante; 2005 Ram,2010 Ram,2018 Ram. Never a problem.
Those Volant intakes seem to be overlooked a lot but from what I’ve seen of them online they look like a good intake. That Powercore filter is interesting too...
Yukonbill
Williamsburg
6.7 Diesel
I just bought a 2016 Ram Express with the 5.7 Hemi. I want to put a cold air intake on the truck, any suggestions as to brand? Open box or enclosed box?
Why do you think you know more than the engineers? If you read the specifications on the cold air intake, most don’t add any improved hp until you are around 8,000 RPM, which, is totally unrealistic because you will “red line” at about 6500. I purchased a cold air system years ago, on an 05’ Ram 1500, 5.7 Hemi. And never seen improvement in power nor fuel efficiency improvement. Most cold air intake systems manufactures want you to purchase aftermarket PCM upgrades to override Manufactures setting. But that’s very costly for minimum gain. My suggestion is if you want such system research and do some product reviews from users not what’s published on their websites, because, many of those “5” star rating are coming from in house not real users. Best of luck.
Pull Ya
Cedar Creek, Tx
Real users have found there is an improvement in performance on the track when using a Vararam. IMHO stock trucks are factory equipped and tuned for the general public. If you want to increase the performance there are associated costs---remember the saying--"Going fast costs money, so just how fast do you want to go"? How much of an increase in performance you want is your decision, how much of an increase each bolt on provides is and has been an ongoing discussion.
Jay
ScLeCo
Earth
Supercharged 426
I love mine.
Hemi395
Cape Cod MA
I love mine.
You have the scoop too right? Which filter? I tracked down an older model S&B with the lower scoop which was NOT easy to find. I wish I had seen the Volant had the lower scoop too before I hunted those down...
ScLeCo
Earth
Supercharged 426
Yes I have the scoop and the Donaldson filter.
Yeah those S&B scoops are hard to find. I was looking but gave up and went with the Volant.
Edit: Also I thought I read that the S&B air scoop intake was located behind the passenger side tire and people were complaining of dust and mud being kicked up into it?
tomb
ontario canada
2012 bighorn-cherry red
I tell you, my smile was big when stomping on it when stock, but it’s ear to ******* ear with the snarling growl of an exhaust and S&b intake!
I believe you-Ive heard some of them locally--but I think i will have to wait until I actually need a new exhaust-unless I fall into some unexpected cash.Just cant see cutting off a perfectly good system. First time I wished something would wear out sooner than later.
scott lass 18
rocklin ca
2010 ram 1500
so now after 9 years they made a air induction for my volant ! did my own drain pipe fiberglass in bumper cant see it on freeway once got 21.6 mpg and now cooler wow it sooo boost the power I feel but in summer engine sooo hot air out side is cooler so runs better I feel ! now can get on ebay cheaper and a california sticker lone time awaiting ! I have it programmed 91 oct and better setting so it has the power I sooo love ! to each there own oh one thing I did block off side towards fender look in side fender a square flange bet it lets dirt right in to ur air cleaner anyone else see this ?
ScLeCo
Earth
Supercharged 426
:confused:
tomb
ontario canada
Stock box, drop in high flow filter and a add a tube 3" from box to behind front bumper helped my stock motor pull better/longer. Kind of like an added breath on upper rpm/wot!
Oh, and paint for another 5 hp...lol
I thought of trying that-just figured the air would be same temp as that from the wheel-well, perhaps it does help by forcing air in at cruising speeds-- I may try-its cheap enough,however weather is going to ***** now-wish I tried it in the summer!
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
It definately wasn't/isn't about the air TEMP more about the air FLOW. Ambient air from either place, bumper or fender, but added opening and tube means added air intake...
Smokey613
Foley, AL
We did the same thing. We had the Mustang for 7 months. Our “new” 2018 Laramie is in the background. Yes, nice to be back in a RAM. The blue 2014 RAM is what we traded in on the Mustang.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
I question why the rpm quit a 5 thou..The hemi is a 6200 red line..Unless it dramatically drops from 5g on..
OEM shift points are ~5600, unless pulsar tune changes them and to my knowledge it cannot. Never thought to try in manual ERS mode when stock, might be 6K.
