Control arm/cross member.
Rwgarrison23
Salem, Va
My truck have a 4 inch lift kit installed. Now, I'm returning it back to stock. The cross member that sits under neath the differential been cut off to fit the new drop cross member. Since it's going back to factory, do I need to weld that bracket back in place? Does the truck need that factory cross member?
Jbp19classic
Delaware
Yes it needs that crossmember. Technically you could bolt the control arms back in and probably drive the truck without it, but without that crossmember connecting the two control arms to each other the handling and overall structural strength and integrity would be compromised. I wouldn’t feel safe driving it like that.
Fyrwalker
Gurnee illinois
I'm doing the same. Luckily the right side was just unbolted but the left sid ewas cut. Anybody ever get a cut-off peice after installing a lift kit? Trying a junk yard now to match up the cut off.
Mack20classic
Indianapolis
2020 classic
Brother! Pleaseeeee tell me you made a solution here! I’m trying to return to stock myself and back to stock tire size. I’m going to have to try a savage hard myself ad I was an idiot and didn’t save the cut off pieces! Please help me out and give an update and some pics if possible. Also did you MIG?
jws123
nj
go to a slvage yard get what ya need and weld. or just sell the truck and get another one that hasnt been abused/lifted.
Mack20classic
Indianapolis
2020 classic
Go both sides from a donor truck. I’ll take some measurements then weld them up with the miller mig. I’ll sand blast and paint them prior to installing. I’ll keep everyone posted once the truck is back together. Probably tear down the truck tomorrow and then reassemble next few days. Ready to shed this weight and be back to stock height/percormance. One huge bonus is since I have 3.92s my power will restore with factory 31.5” tires. I went with a V rated tire and KYB struts and shocks. The new Moe’s performance cam will thank me for the weight shed I think.
Mack20classic
Indianapolis
2020 classic
Well everyone, I got the donor pieces sandblasted, laid out my measurements on them, cut them out, and then used the miller mig to burn them in. I’m not pro welder but it didn’t turn out to bad. These are pics after painting them. Now I wait for the IHC 3/5 drop kit to arrive. I got the kyb struts in the mail, front end is tore down and just waiting for drop kit to get here. I
As we were talking earlier Mack,i think you did a hell'va job gluing it back together,nothing wrong with your welding skills.
