fulltimerart
I have seen some stories about problems with crank and/or cam position sensors. My 98 1500 5.2, 2 wd, automatic is coming up on 210,000 miles and is running good. The heads were removed and checked (had a coolant leak) and replaced with all new gaskets, plugs and ign wires and dist cap and rotor, the water pump, alternator and belt were also replaced recently. Should I replace the 2 sensors as PM at this miles or possibly buy ones to have on hand when needed? Are there any other items I should change as a precaution or keep on hand? The truck is in very good condition and I want to keep it. Thanks for your help and ideas. Art
