Cylinder heads
malsup83
Arkansas
I hate to ask this question, nut is there a difference in the driver side and passenger side heads.
Just bought new ones for my truck and am stumped. Just got off work and it's making feel feel stupid.
M
malsup83
Arkansas
I know there's a difference in intake and exhaust ports. Just not sure if it matters which is on driver or passenger
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Yes. They are specific to each side of the block
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
as seen in pic p side head will have the egr base mount even the non egr head still has that base just no hole in it. as seen there is a difference in both and they only go on that one way
0219210900.jpg\)
M
malsup83
Arkansas
Awesome. Thanks, finally make some progress again. Cant wait to get her running again and hear less ticking and no motor issues
RamRod37
Georgetown TN
been there done that already that is where that pic come from when I done mine
James OBrien
St. Louis
5.7 Hermi
Same here... Glad you asked, and you didn't learn a hard lesson like I did when you went to bolt on your exhaust headers...
jws123
nj
Also remember 2 different head gaskets each side is diff dont mix them up.
M
malsup83
Arkansas
Yep. Got those right. Heads are on. Been raining all day today so going to torque them down in the morning.
EdGs
FL
Can you really get them backwards?
Isn't there a locating dowel?
Sorry if these questions seem stupid. Haven't had to get into one of these (and hopefully never have to).
Fast69Mopar
Yes you can install them backwards and on the opposite side. The dowel pins are in the same spot on each cylinder head so they will bolt up. As long as you verify that you have the EGR pad facing forward on the right (passenger) side and the accessory bolt holes facing forward on the left (driver) side you are installing them correctly.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Even some of the best make mistakes
Watch the end
Watch the beginning
