I found a fix to my problem which was just the backlight on the gauges were staying lit and draining the battery overnight. The difference between them being on and off is so subtle that I didn't realize it at first.
Short story is that I had a faulty AC and Heating control module beside the glove box. I replaced it and all is now good.
Long story: this is the Rube Goldberg of how to drain your battery. It starts with the infamous leaky third brake light. A few months after i bought the truck I noticed the headliner in the back corners were getting wet from an obvious roof leak. The dealer knew what was going on right away and replaced the stock gasket with a foam weather strip and some silicon.
Well I guess after a few years that foam weather seal broke down because I noticed the leak came back after a heavy rainstorm earlier this year. This time the water pooled up in the front right corner in front of the passenger seat, because of the angle my truck sits on the driveway. No worries, my weather tech floor mats kept the carpet from getting wet. But the problem I did have was that when I started the truck, the climate control system did not turn on. In fact the controls on the screen and the lights on the knobs didn't work. It was like it wasn't installed. So I pulled out the glove box and looked at the control module and sure enough, it was wet from the leak and I could smell burnt electronics. Well I knew enough about electronics to know that if you let them dry, they might still work. Sure enough, the next day after everything dried out, the climate control worked again. Hallelujah! I didn't have to spend $150 for a new one.
Well, what I didn't notice until a few weeks later and waking up to a dead battery a couple of times, which I blamed on a cheap battery that i had bought about the same time, was that the back light on the gauges were not turning off, and I wasn't hearing that creaking sound of the actuators on the vent doors closing anymore a minute after shutting off the engine. Once I realized that there was a shutdown sequence that was getting stuck somewhere, and doing some research, it all led back to that heating control module. I tested my theory and unplugged the module, and sure enough the lights would shut off as expected.
So I spent $150 on a new module on Ebay, and now everything is back to normal. Next step is to tear off that foam weather strip and replace it with a marine grade weather strip per advice on another thread forum.
