Dealer oil change...& "Gas Cap" dash light.
Tumbleweed
Well it was oil change time, along with a dash light for "gas cap".
I was planning on doing my own oil change but nothing I tried would turn off the light. Took cap off and put it back on...nope. Swapped with my Jeep's gas cap...nope. Checked the evap box under the truck bed in case I'd hit something on the road...nope. ( I'd broken an evap box on a rock w/ my Jeep. )
Dealer oil change people couldn't fix the light. I've been told it's not a current issue, but a permanent code...stored in the RADIO. That they can't clear! Next full appointment is Thursday. Gotta love technology!
Tumbleweed
Tumbleweed
U*P*D*A*T*E
Well after disconnecting the battery for a couple of hours, it seems like the light has gone out. I still have the appointment for Thursday, but will cancel it if the light remains off.
chri5k
USA
Diesel
Can they at least make their BS believable? The radio does not store trouble codes. It would be more plausible if they said the BCM had stored the code. I hope you didn't laugh too hard when they told that BS story.
Tach_tech
5.7L HEMI
Gas cap light has to be cleared by resetting the PCM. You can clear the evap leak code but it won’t clear the warning, until you do a PCM reset. Disconnecting the battery for 20 minutes will cause the PCM to reset.
