Dee Zee Tailgate Assist Shock
jadocs
Anyone know if this will work with the 2014 2500 tailgate? Just trying to confirm....thanks
My buddy has one on his Chebby and I liked how it worked.
Yes that's what I have. This is what I ordered. The part number is in the ad. I also crossed referenced it with the deezee website.
jadocs
Secretly it's my favorite mod. No issues whatsoever and quicker to remove from the truck if I want to clean the bed or haul REALLY nasty stuff. and SOOOOO much easier on the knees than the bed liner.
I just put in an offer on eBay for one. You have good taste in mods my man.
sbarron
Wasilla, Alaska
Thanks. I've tried to keep the truck looking stock, yet better, so the little details catch your eye rather than being over the top with the mods.
And if it doesn't improve the function somehow, I'm not very interested.
Bombdigitty
Have it. Love it. Recommend it.
Mine is starting to come loose though. The mounting of the ball in the tailgate is a bit cheezy.
chapnutz1
got mine from ebay, $26 and change shipped
jadocs
Where is it coming loose? Is it that piece that you install with the tool on the tailgate?
Awastatyme
Southeast Texas
2015 Ram 1500 Crew Cab Laramie
How much resistance does the shock give when you try to close the tailgate?
nyciti
So I bought one maybe 2 weeks after I got my truck and it sat for a year before I put it on ...what a stupid move. It is a great mod for the cost!! I have played with the idea of putting another one on the drivers side...works great!!
Only complaint is be mindful of the hardware that comes with it. Mine had the wrong stuff in it but they fixed ASAP no problems, so great support too.
Bill507
New Orleans
So mine came in today and I installed it. Awesome $29 mod. Thanks for bringing it to my attention.
Does just the one side handle the gate weight or would one for each side help? Looks great on your truck btw.
Sent from my SM-G900V using Tapatalk
sbarron
Wasilla, Alaska
Only one needed. Handles the weight fine. Only trick is to install correctly and periodically check for tightness. Use red threadlock.
jadocs
Bill thanks. As SB said only one is needed. It works fantastic.
Here is an install video that shows you what needs to be done. The only difference is use red loctite not what is supplied.
http://youtu.be/Idz2ptBuIno
Bill507
New Orleans
Just ordered mine! [emoji3]
TerraNewf
NL, Canada
Mine came loose after a month, had to retighten and use red locktite
jadocs
Oh just one more note. After I removed the limiter on the cable, I added a small washer and put it in its place. The limiter essentially acts as a washer and when you remove it to enable more range of movement the cable end could rub the tailgate directly.
sbarron
Wasilla, Alaska
Good idea. Know what I'm doing today.
EagleChief
Oklahoma
2014 Big Horn
Talked my neighbor into ordering one for his PowerWagon. :D Didn't take much convincing though... once I showed him how it worked, he almost ran inside to go order it.
