Determining axle ratios
Lucky Dog
USA
Hemi 6.1
Just purchased a 2009 Big Horn 1500 and would like to know how to determine its' axle ratios. Is there a build label somewhere on the truck?
Krein
Red Lion, PA
There should be a label on the rear axle with the ratio if not google (ram vin build sheet) and you can go from there. Just enter your vin#
jasonw
South Dakota
3.0L Hurricane HO
The tag on the rear axle wears off pretty quick, but sometimes you get lucky. Another place to find it is on the transfer case, if you have a 4x4. It'll be on the back, underside of the case.
Here is a pic of the one from my 2013 before it was totaled.
Otherwise, Krein is correct, a build sheet will tell you.
Dwight Schrute
Somewhere on a mountain
The build sheet gives two sections. "Standard" and "optional".
Am I reading this right. The standard list is what all trucks (this model/trim) came with. The optional is extras that the original owner got with the truck? So if the 3.92 is listed under "optional". That's what my truck would have.
joshhhh
