DIY - add Auxiliary switches to a 2016 RAM 2500 Tradesman
ISKRA
Tacoma, WA
It took a lot of research, but I finally figured it out! If you do not have an upfitter harness or wiring, you can make your own as described in this thread. I was stuck with the OEM connector and how to wire my switches. If you want to save yourself a lot of time to avoid drilling, soldering and keep a nice clean look, here are the part numbers:
Manufacturer: TE Connectivity
Connector part #: 1456989-3
Terminal (pins, female) 18 AWG: 1393366-1
We all have the connector already so you just need the terminals. Hope this helped, took me close to 6 months of research to find that.
Power247
High Point, NC
6.4 HEMI
Thanks to all that contributed to the info in the thread.
Greg
2012 | RAM 2500 | CCSB | Custom tuned by Double R Diesel
2016 | Heartland Pioneer | DS310
Manchester, CT
The wiring will not be present at the connector on 1500 trucks. A while back a former member who passed away jeepguy1980 tried to put one in his 1500 and when he did the top switches would not work either.
Sent from my iPhone using Tapatalk[/
Has anybody come up with a harness that will plug into the back of the switch pod for a 1500?
Gene Carey Sr
Rome New York
im wanting to do this diy and was very disappointed i couldnt until i read you post what im confused at is where does the harness come into play from switches to fuse panel? do you have a pic of the back of the switches i wan to run my fire dept lightbar from these
Mega Man
Littleton, Colorado
Huge thumbs up for this, I may try to find the other connector and removable for this, so we can make our own truly plug and play system
Mega Man
Littleton, Colorado
I got info back from te, thanks to you
The mating connector for TE Part # 1456989-3 is TE Part # 1438170-1. The terminal Part # will depend on your Wire Size. Attached is a catalog for this connector series. You can find the Receptacle Terminals/Contacts on page 22 and the Pin Terminals/Contacts on page 23. These pages will also show the tooling that is suggested for the connectors as well as additional technical information/features.
Hope this helps, now you can make a harness so the aux buttons address all plug and play , so no permanent mods during install
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
So the pics on that website arent loading for me. You saying if I get both of those I can just make a harness that will plug right into where those switches go? I've been meaning to find out the connectors but if these are forsure them I will get them ordered. You order directly from them or find a vendor?
Mega Man
Littleton, Colorado
Mods , if this is against tos, I am sorry. I am part of several forums and I don't remember all the rules to each,
I purchased mine from mouser, they were the only ones I could just buy 1 from. I got a quote for another site for 10.
I don't have 100% verification, as i am still waiting for mine. But yes should be. The Male seems to work. Although it may not have the right key. But idc as long as it fits. I can update when the female arrives.
The female pins are accurate however
abbttb
abbttb
Austin Tx
Update: When I installed my Aux switches orginally, switch 1 and 2 would function with the ignition off and 3-5 required the key to be in the on position. I recently picked up an OBDLink MX 426101 bluetooth scantool on Amazon and then purchase the AlphaOBD app through the Google play store for Android. Using the Alphaobd app with the OBDLink MX, I was able to access the body computer and enable the Aux switch features. Now I have control to designate the switch as momentary or latching and choose if it is battery or switched powered through my EVIC.
As a side note I was also able to enable my DRLs using the Alphaobd app with the OBDLink MX and choose which lamp I wanted designated as the DRL. I'm still exploring other enablement options.
Sent from my SM-N950U using Tapatalk
89ccecda4c89b8bf1a972741692570bd.jpgf3724dfd8b5051a26bbc19f865199e7e.jpg7bcf11186b9596de342c25cef4e9df04.jpg91456e92689beca03115950b97b5661b.jpg9ff14ed9a20f685214a0e75dd4b2790b.jpg6159a5afa5077bad1351457ff77188cb.jpg7d152a95c707cdb0795a1ce9c9c6b131.jpg9a7ac181d9844f79a44711868e5b20b2.jpg0e4420e0105272e9956ec109dca86a4c.jpg
tnctx02
2017 RAM SLT
3.6L Pentastar V6
The OBDLink MX works fine to use with AlphaOBd? Don't need the MX+?
abbttb
abbttb
Austin Tx
The OBDLINK MX version worked great. I did not need the MX+ce075b2f1a20f933164e68475011c897.jpg
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Thanks so much for the info!
Special K
AL
HEMI 6.4
So I’m newish to the forum and want to do this upgrade. I can work my way through most electrical projects but wanted to see what gauge wire you recommend using going from the connector to the relays? Thanks in advance.
abbttb
abbttb
Austin Tx
I used 14 gauge wire from the aux switch to the relay and 12 gauge wire from the battery + & ground, battery + runs through my auxiliary fuse box to the relay. I'm sure it's a little overkill.
Canadian Mopar
Alberta
2017 2500 SLT
Finally finished installing these in my '17 2500 last night. Only problem I am having is the Aux switch CSM doesn't show up in my radio (it shows up in my 7" cluster under the commercial settings though) and when I go through the commercial settings menu and check the "last state" of a switch it pops up with an error, says something about checking the owners manual.
It is also possible to get everything from a OEM setup and wire it like OEM (you could add a PTO this way as well), I'll take some pictures and get a list of all the terminals and connectors I used if someone is interested in doing the same.
Special K
AL
HEMI 6.4
I’m in
I’m interested if you have a write up on it
Special K
AL
HEMI 6.4
Sorry, been meaning to do this. Hopefully I'll be able to get some pics / parts list this week.
Just to clarify, you are saying that if I found a parts truck with the Aux switches installed I could wire it up myself?
TMFMK
