Drain plug?
sam1286
Ohio
Cummins
anyone know what size the oil pan drain plug bolt is on a 2013 6.7L?
DannyMK2
Long Island, NY
2015 Power Wagon
i doubt cummins has changed the oil plug, so its most likely a 3/8" ratchet, no socket.
Keep It Cummins
Cummins ISB 6.7 L
Dude!!! Do yourself a hugh time saving AND MESS SAVING favor! Order the Fumoto quick drain valve TODAY!! Secure the quick valve with a small adjustable hose clamp and keep it on the down low. You will love this gadget after you use it the first time. No Nipple No hose! Trust me and you can thank me later.
mjd91
San Marcos, TX
The Fumoto valve is pretty nifty. I had one on my cummins.
Used a little ring clamp and wala, no possible way if it coming open.
Ramunit
I love my fumoto
ceide4489
Cummins
I looked and just cant bring myself to use one for fear of it coming open
Then should make it with a plug that can be put in so can pull plug and then open valve to drain
Would be simple to make to use the drain plug that was removed from the oil pan to instal
ceide4489
Cummins
I am just as worried about it being broke off while out in deep mud
Soddy
Granville
6.7 Turbo Diesel
If you get the valve with no nipple on it there really isn't much hanging down. I never felt the need to put a hose clamp around the valve and went through a lot of corn fields after harvest without any troubles, it stays pretty solid in the pan.
ceide4489
Cummins
Big difference between driving in a corn field and driving in the oilfield where locations are always muddy with big potholes and rock all around
They are probably a great drain valve for those driving on hwy but I would have a real hard time with one in an offroad application
