Driveline suspension issue
Clebreton
Edmonton Canada
Not sure if I’m posting in the right spot will give the most details that I can
I have a 2010 dodge ram 1500 5.7 hemi
280,000km just bought it a few days ago for cheap
After driving it for a full day it has started to show a nasty shake/vibration or more like wheel hop from the back
It only does it when I am stopped at a red light, when the light goes green and I take my food off the gas and give it a light amount off gas it feels like the tires aren’t getting traction. If I give it to much gas the tires bounce and the entire truck shakes violently. It does it in 4x4 as well
I have replace the tires 2x and had them balanced to make sure it wasn’t that
I have done to 3 shops to get a diagnostics
First one said it was the differential needed a fluid change so I did that myself (with proper fluid) and said that the differential is shot
Second shop said it’s the drive shaft but the first shop said drive shaft is fine
third shop said rear drivers side calliper is sticking causing it to wheel hop until the piston releases. They also checked all my suspension that the other shops didn’t
Rear control arm bushings are shot and track bar bushing are shot, say bar bushings front and back are shot drivers side cv axle needs to be replace and front tire rod ends both sides
Would a sticking calliper cause wheel hop is my main question. I ordered all the suspension parts but have not gone ahead with the callipers in the rear yet
Atcer2018
Virginia
Can’t say for sure if it’s the sticky caliper but if the caliper is sticking it will need to be rebuilt or replaced anyway. A badly sticking caliper can cause a vibration in a car, no experience with a truck but it sounds reasonable.
mdc1990zr1
Conshohocken, PA
I had drum brakes do that to me on a previous Chevy. Wheel would momentarily lock up and skip. Check your parking brake shoes. They are known to separate from the backing plate. This will cause your symptoms
Try turning the Traction Control off.
Also check if the truck has Hill Start Assist, turn that off too(your truck may not have this option as I think it may be for '13 and newer trucks).
C
Clebreton
Edmonton Canada
Still does it in traction control and I don’t have the hill start assist
Another think it doesn’t doing it if I’m rolling so only after applying brakes at a complete stop
C
Clebreton
Edmonton Canada
That could be it my park break cable is hanging down
C
Clebreton
Edmonton Canada
So got the truck up on stands. Don’t think it’s the callipers or park break. Tires move freely
I imitated the the symptoms
Seams like it’s coming from
Drive shaft, transfer case or transmission
Being an Edmonton truck with close to 300,000 clics on it,i wouldn't be surprised if it needed u-joints in the rear driveshaft or front cv axles
DILLIGAF
Canadian Forces
Canada
Pull you rear driveshaft and go for a drive in 4wd
Pull your front driveshafts and go for a drive.
Pull the front diff / CVs / driveshaft out and go for a drive
C
Clebreton
Edmonton Canada
Right?! I just picked up U-joints for it and the cv axles are in good shape I believe they were done with the lower control arms
Upper on other had there is some play in the bushings.
C
Clebreton
Edmonton Canada
Ok so finally got my code reader to work with my truck ‍♂️
I’m getting some transmission fault codes
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
Maybe shift solenoid or dirty filter/ tans fluid ?
Could this be causing the wheel hop
Notice that when I’m at a light it feels like drag then the tires feel like they are hopping. If kind of pump the gas it will stop but doesn’t all the time
C
Clebreton
Edmonton Canada
Got around to getting the rear drive shaft on took it for a drive in 4x4 still did it
Took the front drive shaft off and it started to rain before I could get the could get at the cvs
I did notice there is a decent amount of play in the transfer case support bushings
C
Clebreton
Edmonton Canada
Ok so I did all this on top I replaced
Upper control/ ball joints arms both sides
Lower ball joints both side and tie rods sway bar bushing and links
It still does it. Could this be the transmission? Transmission mounts?
I am lost on what it is
C
Clebreton
Edmonton Canada
Ralph Mauro
Otonabee On
If it shakes that bad and the problem is in the rear brakes one of the rear wheels should be hotter than a firecracker after a drive. Assuming it has to do with parking shoes or calipers hanging up
C
Clebreton
Edmonton Canada
Replace rear parking shoes and calipers rotors and pads today bled the breaks and still does it.
Marshall
Sk, Canada
2014 sport
After you do motor mounts, have you tried stopping (if it works) with just the park brake and not the reg. brakes, would cut out using the calibers, What about when you back up, Any different?
Sounds like brake lock up to me.
If you have it up on jack stands, and it's safe, run the rear axel and hit the brakes, then turn off the truck and see if you can turn the wheel or not by hand. You could also check parking brake the same way to see if they release or bind up
Would work way better on a lift, you could watch all the wheels and drive shaft.
I had a 2010 , great truck , till a chev idiot in Saskatoon run into me and insurance wrote it off.
