DRL question
purcell1
hemi
Canadian with a Canadian truck.
Long story short I need my drls disabled as I went from a quad headlight to a single projector with and hid kit. However the drls cause my cutoff to flicker as well as the hids.
With the lights on they work great.
I’ve called the local dealerships and they won’t disable them as it’s illegal here in Canada.
What’s my options? Drive across the border and try there haha?
Ideally I want to switch to my amber corners/turn signals as my drls.
While I’ve got you all. I want to run a yellow led foglight, do I need a canbus harness or can I just run s regular 6ohm load resister?
Thanks guys!
17db328b205ddaccdfc56a776ee700e7.jpgView attachment 153100
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
What year truck? As I recall this won’t work on 2009-2012 correct, only 2013+
2009 QCRB 4WD - 4.56/Shorties/FMTB/Intake/Exhaust/6” on 35’s/lots more [emoji41]
P
purcell1
hemi
It’s a 2018 big horn. I’m currently reading through the alpha thread. I’m on post 100- long way to go lol.
Does it affect warranty at all? Like is the dealership able to see that I have been into the bcm
Rebel-416
Toronto
Weird, I thought the ambers were supposed to be the DRL’s. I’m in Ontario and just picked up my 2017 Rebel from a dealer a month ago and that’s how mine came. Could have swore the other ones I looked at were the same.
JB1
Houston, Texas
P
purcell1
hemi
My truck came with quad reflectors. I swapped in a set of housings and projectors.
kad
Hudson Valley, NY
5.7L HEMI
Ambers are used as DRLs on the projector headlights, quads use the high beams on half power, hence the OP's issue. AlphaOBD is indeed the solution!
-K
Richmond2000
as a Canadian with "quad" headlights
FACTORY setting is hi beams dimmed
I used AlphaOBD and switched to front turn for DRL and it works as expected
also has the OPTION for FOG lights
RAMTRPR
Brentwood, CA
Do you have the settings you changed by chance? I am trying to do the same to mine. You can pm me or post them in the AlfaOBD for 09-12 rams thread.
Thanks
Richmond2000
Thanks
mine is a 2014
Ambient Temperature Sensor Present: Not set
CBC Features Configuration:
Tip Start Enabled: Set
Dual Start Relay System Present: Not set
Wiper Service Position Enabled: Not set
AUX High Beam Present: Not set
Trailer Tow Present: Set
Quad Headlamps Enable: Set
Horn Chirp Allowed: Set
Bi Xenon Headlamps Enable: Not set
Hazard Lamp Configuration: Latching Switch
Park Lamp Loadshed Enable: Set
Front Fog Lamp Dropout Enable: Set
Combined Rear Lighting Enable: Set
Side Repeaters Enable: Not set
One Touch Lane Change: Set
Exterior Light Loadshed Enable: Set
Front Wiper Park Enable: Set
Rear Wiper Park Enable: Not set
Reversible Washer Pump Enable: Not set
Single Element Tail Lamp: Not set
DRL Configuration: Canada DRL
DRL Lamp Location: High Beam DRL
DRL Dropout Enable: Set
Tunnel Detection: Not set
Rear Lighting DTC Disable: Not set
LED Reverse Lamps Present: Not set
DRL Lamp location change to turn lights OR fog lights
DRL Dropout is if the lDRL turns off during turn signal on that side if you use FOG I would turn that off
